New install of Home Assistant web interface won't load Topic is solved
xtrezpasor
Re: New install of Home Assistant web interface won't load
Post by xtrezpasor »
I cannot seem to get Home Automation to work properly - I get the 404 error when i try access it, I attempted to follow the buster update instructions and they didnt appear to work properly - plus i run SONARR so i'm unsure if this will be an issue.
could you share the log
journalctl -u home-assistant.service
