AdGuard Topic is solved
NoLifer
Re: AdGuard
Post by NoLifer »
The only reason why ntfs it's because easy to acces files if I connect it to PC with Windows
Re: AdGuard
ok indeed seems to be an issue using a NTFS drive. I will submit a change for next release to have correct permissions even if user data is located on NTFS.
