network storage related questions.. Topic is solved
kannz
Re: network storage related questions..
Post by kannz »
hmm rutorrent keeps freezing and its plugins are crashing. deluge will not let me log in to its webui and transmission wont download in a stable way. should i try to reinstall dietpi? samba seems to works fine though.
probably you need to check memory usage how it goes.
free -m
kannz
Post by kannz »
um now ive wiped my sdcard and im now unable to reinstall dietpi as it says it cant handshake or something.. its after i log in with root/dietpi then it says a bunch of stuff that goes by to quick and asks me if i want to retry something that failed..
It is impossible to help you, if you don't share real error message or logs.
kannz
Post by kannz »
it didnt give me an error it just asked me to retry apt get update because it failed something and it couldnt trust a certificate. when i go back to it tomorrow ill post some kind of error or a screenshot/log.
if there are certificate issues, you maybe running out of time sync.
Yes a log and or screen print would be helpful.
kannz
Post by kannz »
Okay I think I added a capture of the error.
Ok that's a known issue at Debian server side. Pls try follow
sed -i 's/https:/http:/' /etc/apt/sources.list
apt update
apt upgrade
sed -i 's/http:/https:/' /etc/apt/sources.list
apt update
kannz
Post by kannz »
After it does the error I put that in? Glad it's a known problem..I thought I broke it. Heh :)
Just login to command line and execute the commands. Once completed you are ok to run dietpi-update
