Wireguard on dietpi/vmware workstation
Re: Wireguard on dietpi/vmware workstation
strange that you can connect via SSH to your local network (PiHole device) but not using HTTP.
Ok if you have time and mood, we could perform some tcp tracing to check where HTTP connection breaks.
thejuan
Post by thejuan »
It is strange, I was surprised ssh worked, good call!
Sure, I'm down, I really appreciate the help!
I might not be timely today but I'd like to solve this, it's been bugging me
trendy
Post by trendy »
Can we verify first that it is not blocked by the firewall?
iptables-save -c
thejuan
Post by thejuan »
iptables-save -c
# Generated by xtables-save v1.8.2 on Thu Sep  2 19:34:10 2021
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
[4342:671586] -A FORWARD -i wg0 -j ACCEPT
COMMIT
# Completed on Thu Sep  2 19:34:10 2021
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
[791:52332] -A POSTROUTING -o eth0 -j MASQUERADE
COMMIT
@thejuan
is the following correct?
IP PiHole VM - 192.168.1.24
IP WireGuard VM - 192.168.1.25
IP WireGuard Client - 10.9.0.2
if yes, I will let you know the commands we would need to capture the HTTP connection
trendy
Post by trendy »
Install tcpdump apt install tcpdump and then run:
tcpdump -evn tcp port 80
thejuan
Post by thejuan »
yes, the ip's are correct
Ok I will post tcpdump command later the evening. I played with it and I guess I found a good filter to show important information only.
thejuan
Post by thejuan »
awesome! thanks so much for the help
ok for testing install tcpdump on both VM's
dietpi-software install 15
Following will start traffic capture on WireGuard VM
tcpdump -i any -c200 -nn port 80 and '((src 10.9.0.2 and dst 192.168.1.24) or (src 192.168.1.24 and dst 10.9.0.2))'
  • it will capture 200 lines
  • on HTTP port 80
  • where source is wg client IP 10.9.0.2 and target PiHole VM for incomming traffic
  • and the other way around to check on an answer
Following will start traffic capture on PiHole VM
  • on HTTP port 80
  • traffic from all sources will be captured
Test to be done
  1. Ensure no device on your network is actually connected to PiHole web interface
  2. connect your mobile device to cellular network
  3. connect WireGuard app
  4. open web browser and try pi.hole/admin/
  5. close browser window
  6. disconnect WireGuard app
  7. you could cancel tcpdump if not already stopped
  8. post output for both VM's
