Apache files to SSD
Burgess85
Re: Apache files to SSD
Post by Burgess85 »
Joulinar wrote: Fri Aug 06, 2021 10:45 pm yes, but you would need to check if the amount of data fits before hand.
Thank you for your help. I think it worked :)
Burgess85
Post by Burgess85 »
Burgess85 wrote: Sat Aug 07, 2021 8:38 pm
Does
the attached look correct?
Looks like root partition is located on sda1 now. It should be correct if all apps working fine.
