Nextcloud install hangs Topic is solved
Re: Nextcloud install hangs
ok great
That should be actually done via dietpi-update as part of v7.2 incremental patches :? https://github.com/MichaIng/DietPi/blob ... #L104-L111
unfortunately we don't know what the DietPi version was at that time. Maybe it was below 7.2 :?
dsscode
Post by dsscode »
This is still happening for me on the latest image DietPI v7.5.2 on oDroid XU4
nextcloud hangs at chown exactly as OP describes
Issue occurs even when preinstalling dependencies via dietpi-software and replacing the system rng as discussed.
we found a Debian bug that might be related to haveged not working correctly on ARM. https://bugs.debian.org/cgi-bin/bugrepo ... bug=985196
can you check following pls if service is on failed status?
systemctl status haveged
