[Plex] File is read-only
RollingDutch
Contact:
Re: [Plex] File is read-only
Post by RollingDutch »
Tried directory /mnt and used nano editor, that failed.
tried direcotry /mnt/dietpi_userdata/volume1/Movies also with nano, and that worked.
I guess you used user dietpi? This is correct that this user can't write to /mnt directly as it is not allowed by file system permission. By default root user is allowed only to write directly into /mnt
RollingDutch
Contact:
Yes, was indeed using user dietpi.
still I'm confused what your issue is now and what you are trying to achieve
RollingDutch
Contact:
What I'm trying is to add the libraries to Plex. they are stored on my nas (192.168.0.10) and I want to be able to watch them on plex. The path on my Synology is /volume1/Movies; /volume1/Series
In /mnt/dietpi_userdata/volume1/ the files are actually visible when logged in as user root, but I still can't add them to the Plex media server.
What is the error message in Plex and can you share
ls -la /mnt/dietpi_userdata/volume1/
