How to turn off colors in terminal?
John Long
Re: How to turn off colors in terminal?
Post by John Long »
It's odd, even xterm +cm doesn't seem to work.
I'm still looking into this.
did you checked your client settings? Maybe you could disable colours at this level.
Jep, client-side seems to be the best option. E.g. for the whiptail dialogues of our scripts the committee's colours cannot be changed, as those are hardcoded in the underlying newt library.
