docker-compose fails to install on Pine A64 on DietPi 7.1.2 Topic is solved
Re: docker-compose fails to install on Pine A64 on DietPi 7.1.2
basically you would have 2 options.
1) download a new fresh Buster image and start a clean install from scratch https://dietpi.com/downloads/images/Die ... -Buster.7z
2) perform an in-place upgrade following this guide viewtopic.php?p=18988#p18988
originally the guide was intended for Raspberry Pi devices but with smaller adjustments on the apt source list'S, it should work on a Pine A64 as well. If all is working fine, Python should be updated to version 3.7 and I would recommend to reinstall Docker Compose after your system has been reboot.
dietpi-software reinstall 134
Disclaimer: Whatever you do, you will do it on your own risk. It's highly recommended to do a full backup of your SD card before. Best would be to clone it, because the upgrade will touch nearly every installed packaged. ;)
tfmeier
Post by tfmeier »
I have rebuilt the Pine64 with the referenced Buster image. All went well (docker, docker-compose) without any errors. Thanks for the help again!
my pleasure
