Hello Community,
i have a problem with a bash-script on my dietpi. In the script ist used the program /bin/logger but there came a message, that the program is not available. I choose the DietPi-RAMlog #1 in dietpi-software. Is the program logger a part of rsyslog and when i install rsyslog, will be the logging into ram still available??
program logger is missing
Re: program logger is missing
did you tried running
According Debian package list, the program
https://packages.debian.org/search?mode ... n%2Flogger
which logger
? Because for me this is returning /usr/bin/logger
logger
is available from apt package bsdutils
Indeed
Note that the primary syslog daemon since Debian Jessie is systemd-journald, making all logs available via
bsdutils
is pre-installed as essential package on all Debian-based distros, otherwise core system features would not work, and the logger command is and always was located at /usr/bin/logger
.Note that the primary syslog daemon since Debian Jessie is systemd-journald, making all logs available via
journalctl
. When you install rsyslog, systemd-journald forwards/duplicates the logs to rsyslog and hence the /var/log/syslog|daemon.log|kernel.log etc plain text log files. But this is not required when you're fine with using journalctl
, which is natively a RAM-based logging. journalctl -t <tag>
can be used to show only logs that match the tag that you set via logger -t <tag> ...
option.
