mariadb fails to start Topic is solved
Re: mariadb fails to start
(sory for replying so late, but had some personal problems)
nothing to be sorry about. Hope you are healthy and ok
Now I must find a way to get a backup of the WordPress database.
Keep your SD card. Once you have setup the new system we could perform some file system check to see if there is a corruption and probably we are able to fix (without guarantee)
RollingDutch
Contact:
Post by RollingDutch »
Thanks. Will do so later this week.
RollingDutch
Contact:
Took a little more longer, but finally having some time for this again.
I installed a new version of DietPi and WordPress on a fresh SD-card, and save the old one to investigate the old disk. If nothng works, no big problem.
If possible you can connect your old SD card via USB connector to your device and run a file system check
fsck -a /dev/sdxx
You would need to replace sdxx with the correct device name. probably sda2
RollingDutch
Contact:
fsck -a /dev/sda2
fsck from util-linux 2.33.1
fsck.ext2: No such file or directory while trying to open /dev/sda2
Possibly non-existent device?
Same with sda1 to sda4
when I tried to look at the card earlier, I got a 'RAW' error message.
let's check where the SD card is
and kernel error messages
dmesg -l err,crit,alert,emerg
RollingDutch
Contact:
Then I get the following:
root@DietPi:~# lsblk -o name,fstype,label,size,ro,type,mountpoint,partuuid,uuid
NAME     FSTYPE LABEL  SIZE RO TYPE MOUNTPOINT PARTUUID                             UUID
sda                   29.5G  0 disk
mmcblk0               29.8G  0 disk
├─mmcblk0p1
│        vfat   boot   256M  0 part /boot      8f4dbd00-01                          4ADC-240F
└─mmcblk0p2
         ext4   rootfs
                      29.6G  0 part /          8f4dbd00-02                          89cef7ba-d45a-47e7-8d42-aff18afcec80
root@DietPi:~# dmesg -l err,crit,alert,emerg
[    5.100383] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
[    5.100401] [vc_sm_connected_init]: failed to initialize shared memory service
[    5.127675] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[    5.348096] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[    5.642702] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[    5.642788] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[    5.644028] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
[49113.118316] sd 0:0:0:0: [sda] No Caching mode page found
[49113.118338] sd 0:0:0:0: [sda] Assuming drive cache: write through
[49113.147751] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[49113.147767] Buffer I/O error on dev sda, logical block 0, async page read
[49113.149215] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[49113.149229] Buffer I/O error on dev sda, logical block 0, async page read
[49113.293662] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[49113.293690] Buffer I/O error on dev sda, logical block 0, async page read
[49113.310761] blk_update_request: critical medium error, dev sda, sector 61931392 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[49113.312113] blk_update_request: critical medium error, dev sda, sector 61931392 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[49113.312127] Buffer I/O error on dev sda, logical block 7741424, async page read
[50169.487676] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[50169.487690] Buffer I/O error on dev sda, logical block 0, async page read
[50169.489028] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[50169.489045] Buffer I/O error on dev sda, logical block 0, async page read
[50169.494424] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[50169.494444] Buffer I/O error on dev sda, logical block 0, async page read
[50973.712374] sd 0:0:0:0: [sda] No Caching mode page found
[50973.712385] sd 0:0:0:0: [sda] Assuming drive cache: write through
[50973.732974] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[50973.733001] Buffer I/O error on dev sda, logical block 0, async page read
[50973.735051] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[50973.735074] Buffer I/O error on dev sda, logical block 0, async page read
[50973.736978] blk_update_request: critical medium error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[50973.737003] Buffer I/O error on dev sda, logical block 0, async page read
[50973.752188] blk_update_request: critical medium error, dev sda, sector 61931392 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[50973.753692] blk_update_request: critical medium error, dev sda, sector 61931392 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[50973.753706] Buffer I/O error on dev sda, logical block 7741424, async page read
looks like quite some damage on the old SD card
RollingDutch
Contact:
Was afraid of that. Well, no big problem. just starting over again with everything, and maybe I can still import from the old,old source
as well a good time to remember to create backups on regular basis on another disk/stick ;)
