Possible to FTP to DietPi and get to /mnt?
trendy
Re: Possible to FTP to DietPi and get to /mnt?
Post by trendy »
Joulinar wrote: Thu Mar 18, 2021 8:12 pm @trendy can you check install state for OpenSSH client
cat /boot/dietpi/.installed | grep -F [0]
Yeah, sure it is not selected.
dietpi@kakadu:[~]$ cat /boot/dietpi/.installed | grep -F [0]
aSOFTWARE_INSTALL_STATE[0]=0
What device/image you are running
trendy
Post by trendy »
DietPi v7.0.2 (beta) : 13:26 - Παρ 19/03/2021
 - Device model : RPi B (armv6l)
The beta must have been a leftover. I switched back to main after the testing period finished.
Maybe package got installed along with others? We never will find out probably. Running dietpi-update -1 should reinstall master branch
trendy
Post by trendy »
I do not have any system to test currently. If you, however, happen to do some testing for something else, please check if it is there on a freshly installed system. If it is not, try again installing pihole. I cannot think of anything else.
Pi-hole does not pull it as dependency. To check whether it's a dependency of any other installed package, you could simply try to remove it. On confirmation prompt it would show you if/which dependants would be removed together with it: apt remove openssh-client
trendy
Post by trendy »
I did some testing and found out that on one system with dropbear as server, the openssh-client is pulled when sftp-server is installed, which most likely is what could have triggered the installation.
For the other system, in case you switch the ssh server from dropbear to openssh, both client and server are installed. Weirdly, removal of sftp-server asks to remove server too, and removal of client asks to remove both server and sftp as well.
Pretty strange and it doesn't seem to work as I have expected.
Ah that makes all sense. These are the package dependencies:
openssh-server > openssh-sftp-server + openssh-client
openssh-sftp-server > openssh-client
Here an alternative SFTP server that does not pull the OpenSSH dependency: https://packages.debian.org/buster/gesftpserver
But it's SFTP only, no SCP.
