MariaDB error Topic is solved
Zeuskk
Re: MariaDB error
Post by Zeuskk »
Running uninstaller from inside dietpi-software gave me this error:
 DietPi-Software
 Mode: Uninstalling MariaDB: database
[FAILED] DietPi-Software | systemctl start mariadb
│  - Command: systemctl start mariadb                                          │
│  - Exit code: 1                                                              │
│  - DietPi version: v7.0.2 (MichaIng/master) | HW_MODEL: 4 | HW_ARCH: 2 |     │
│ DISTRO: 5        │
│  - Image creator: DietPi Core Team                                           │
│  - Pre-image: Raspbian Lite                                                  │
│  - Error log:        │
│ Job for mariadb.service failed because the control process exited with error │
│ code.        │
│ See "systemctl status mariadb.service" and "journalctl -xe" for details.     │
│     Retry          : Re-run the last command that failed                     │
│     DietPi-Config  : Edit network, APT/NTP mirror settings etc               │
│     Open subshell  : Open a subshell to investigate or solve the issue       │
│     Send report    : Uploads bugreport containing system info to DietPi      │
│                    ●─ Devs only ──────────────────────────────────────●      │
│     Change command : Adjust and rerun the command
And systemctl status mariadb.service gave me:
root@DietPi:~# systemctl status mariadb.service
● mariadb.service - MariaDB 10.3.27 database server
   Loaded: loaded (/lib/systemd/system/mariadb.service; disabled; vendor preset: enabled)
  Drop-In: /etc/systemd/system/mariadb.service.d
           └─dietpi-services_edit.conf
   Active: failed (Result: exit-code) since Wed 2021-03-03 09:52:56 CET; 2min 25s ago
     Docs: man:mysqld(8)
           https://mariadb.com/kb/en/library/systemd/
  Process: 20412 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
  Process: 20413 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
  Process: 20415 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status
=0/SUCCESS)
  Process: 20472 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
 Main PID: 20472 (code=exited, status=1/FAILURE)
   Status: "MariaDB server is down"
mar 03 09:52:54 DietPi systemd[1]: Starting MariaDB 10.3.27 database server...
mar 03 09:52:54 DietPi mysqld[20472]: 2021-03-03  9:52:54 0 [Note] /usr/sbin/mysqld (mysqld 10.3.27-MariaDB-0+deb10u1) starting as process 20472 ...
mar 03 09:52:54 DietPi mysqld[20472]: 2021-03-03  9:52:54 0 [Warning] Could not increase number of max_open_files to more than 16384 (request: 32186)
mar 03 09:52:54 DietPi mysqld[20472]: 2021-03-03  9:52:54 0 [Warning] Can't create test file /var/lib/mysql/DietPi.lower-test
mar 03 09:52:56 DietPi systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
mar 03 09:52:56 DietPi systemd[1]: mariadb.service: Failed with result 'exit-code'.
mar 03 09:52:56 DietPi systemd[1]: Failed to start MariaDB 10.3.27 database server.
I don't know if this is important but I have system installed on external SSD, but I never moved manually any userdata files, folders etc. Just installed system on SSD with uasp enabled without any problems and is working on it for months.
Re: MariaDB error
ah yes, sorry, DietPi is trying to start MariaDB before it goes to remove the packages
let's try it manually
G_AGP mariadb-server
rm -Rf /{mnt/dietpi_userdata,var/lib,var/log,etc}/mysql
this should clean the installation of MariaDB. If this was working, you would need to set aSOFTWARE_INSTALL_STATE[88]=0 inside /boot/dietpi/.installed to clear the installation status. Now, you should be able to install MariaDB again.
Re: MariaDB error
The CLI issue was fixed with: https://github.com/MichaIng/DietPi/comm ... 10eb912271
Changelog: https://github.com/MichaIng/DietPi/comm ... ba4a407530
Many thanks for reporting the issue.
Yeah uninstalling MariaDB is not possible as long as the service cannot start, since it does a database dump. Theoretically we could skip this step, but database content usually is the very most sensible and important data for any software title, so I'd like to keep this step as a measure against accidents. One alternative could be, if the service start fails, to leave the raw database directory in place instead. It is not as good as a database dump, since it cannot easily be imported into any other database server, but with a proper warning it should be fine?
But since you don't use the MariaDB server anymore, the commands suggested by Joulinar are pretty fine to purge it.
Zeuskk
Re: MariaDB error
Post by Zeuskk »
Joulinar wrote: Wed Mar 03, 2021 11:25 am ah yes, sorry, DietPi is trying to start MariaDB before it goes to remove the packages
Strange think is after that commands MariaDB service still exist, dietpi-services shows it on list as 'failed' service. Rebooting system doesn't help.
Or maybe MariaDB and MariaDB Service are two different things? :x
Pushing dietpi-software install 88 give me:
[  OK  ] DietPi-Software | Initialised database
[  OK  ] DietPi-Software | Reading database
 DietPi-Software
 Mode: Automated install
[  OK  ] DietPi-Software | Installing MariaDB: database
[  OK  ] DietPi-Software | Free space check: path=/ | available=76757 MiB | required=500 MiB
[  OK  ] DietPi-Software | DietPi-Userdata validation: /mnt/dietpi_userdata
[  OK  ] DietPi-Software | Checking network connectivity
[  OK  ] DietPi-Software | Checking DNS resolver
[  OK  ] Network time sync | Completed
[ SUB1 ] DietPi-Services > unmask
[  OK  ] DietPi-Services | unmask : proftpd
[  OK  ] DietPi-Services | unmask : redis-server
[  OK  ] DietPi-Services | unmask : mariadb
[  OK  ] DietPi-Services | unmask : php7.3-fpm
[  OK  ] DietPi-Services | unmask : lighttpd
[  OK  ] DietPi-Services | unmask : transmission-daemon
[  OK  ] DietPi-Services | unmask : plexmediaserver
[  OK  ] DietPi-Services | unmask : jackett
[  OK  ] DietPi-Services | unmask : sonarr
[  OK  ] DietPi-Services | unmask : radarr
[  OK  ] DietPi-Services | unmask : bazarr
[  OK  ] DietPi-Services | unmask : docker
[  OK  ] DietPi-Services | unmask : cron
[ SUB1 ] DietPi-Services > stop
[  OK  ] DietPi-Services | stop : cron
[  OK  ] DietPi-Services | stop : docker
[  OK  ] DietPi-Services | stop : bazarr
[  OK  ] DietPi-Services | stop : radarr
[  OK  ] DietPi-Services | stop : sonarr
[  OK  ] DietPi-Services | stop : jackett
[  OK  ] DietPi-Services | stop : plexmediaserver
[  OK  ] DietPi-Services | stop : transmission-daemon
[  OK  ] DietPi-Services | stop : lighttpd
[  OK  ] DietPi-Services | stop : php7.3-fpm
[  OK  ] DietPi-Services | stop : mariadb
[  OK  ] DietPi-Services | stop : redis-server
[  OK  ] DietPi-Services | stop : proftpd
[  OK  ] DietPi-Software | mkdir -p /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads /var/www /opt
[  OK  ] DietPi-Software | chown dietpi:dietpi /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads
[  OK  ] DietPi-Software | chmod 775 /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads
[ INFO ] DietPi-Software | APT update, please wait...
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 https://download.docker.com/linux/raspbian buster InRelease
Hit:3 https://downloads.plex.tv/repo/deb public InRelease
Hit:4 https://download.mono-project.com/repo/debian stable-buster InRelease
Hit:5 https://download.mono-project.com/repo/debian raspbianbuster InRelease
Ign:6 https://mediaarea.net/repo/deb/raspbian buster InRelease
Hit:7 https://mediaarea.net/repo/deb/raspbian buster Release
Hit:8 https://archive.raspberrypi.org/debian buster InRelease
Hit:9 https://apt.sonarr.tv/debian buster InRelease
Reading package lists...
[  OK  ] DietPi-Software | APT update
 DietPi-Software
 Mode: Checking for prerequisite software
 DietPi-Software
 Mode: Installing MariaDB: database
[ INFO ] DietPi-Software | Preparing database directory at: /mnt/dietpi_userdata/mysql
[  OK  ] DietPi-Software | rm -f /mnt/dietpi_userdata/mysql
[  OK  ] DietPi-Software | mkdir -p /mnt/dietpi_userdata/mysql
[  OK  ] DietPi-Software | rm -Rf /var/lib/mysql
[  OK  ] DietPi-Software | ln -s /mnt/dietpi_userdata/mysql /var/lib/mysql
[ INFO ] DietPi-Software | APT install for: mariadb-server php7.3-mysql, please wait...
Selecting previously unselected package mariadb-server.
(Reading database ... 64322 files and directories currently installed.)
Preparing to unpack .../mariadb-server_1%3a10.3.27-0+deb10u1_all.deb ...
Unpacking mariadb-server (1:10.3.27-0+deb10u1) ...
Setting up mariadb-server (1:10.3.27-0+deb10u1) ...
[  OK  ] DietPi-Software | APT install for: mariadb-server php7.3-mysql
 DietPi-Software
 Mode: Configuring MariaDB: database
[ INFO ] DietPi-Software | Assuring 4-byte support and InnoDB Barracuda file format with large prefix
/boot/dietpi/dietpi-software: line 7683: /etc/mysql/mariadb.conf.d/99-dietpi-4byte.cnf: No such file or directory
sed: can't read /etc/mysql/mariadb.conf.d/99-dietpi-4byte.cnf: No such file or directory
[ SUB1 ] DietPi-Services > dietpi_controlled
[  OK  ] DietPi-Services | dietpi_controlled : proftpd
[  OK  ] DietPi-Services | dietpi_controlled : redis-server
[  OK  ] DietPi-Services | dietpi_controlled : mariadb
[  OK  ] DietPi-Services | dietpi_controlled : php7.3-fpm
[  OK  ] DietPi-Services | dietpi_controlled : lighttpd
[  OK  ] DietPi-Services | dietpi_controlled : transmission-daemon
[  OK  ] DietPi-Services | dietpi_controlled : plexmediaserver
[  OK  ] DietPi-Services | dietpi_controlled : jackett
[  OK  ] DietPi-Services | dietpi_controlled : sonarr
[  OK  ] DietPi-Services | dietpi_controlled : radarr
[  OK  ] DietPi-Services | dietpi_controlled : bazarr
[  OK  ] DietPi-Services | dietpi_controlled : docker
[  OK  ] DietPi-Services | dietpi_controlled : cron
[ SUB1 ] DietPi-Set_hardware > headless (disable)
[  OK  ] DietPi-Set_hardware | Desired setting in /boot/dietpi.txt was already set: AUTO_SETUP_HEADLESS=0
[  OK  ] headless disable | Completed
[  OK  ] DietPi-Survey | Sending survey data
 DietPi-Software
 Mode: Installation completed
[ SUB1 ] DietPi-Services > restart
[  OK  ] DietPi-Services | restart : proftpd
[  OK  ] DietPi-Services | restart : redis-server
[FAILED] DietPi-Services | restart : mariadb
[  OK  ] DietPi-Services | restart : php7.3-fpm
[  OK  ] DietPi-Services | restart : lighttpd
[  OK  ] DietPi-Services | restart : transmission-daemon
[  OK  ] DietPi-Services | restart : plexmediaserver
[  OK  ] DietPi-Services | restart : jackett
[  OK  ] DietPi-Services | restart : sonarr
[  OK  ] DietPi-Services | restart : radarr
[  OK  ] DietPi-Services | restart : bazarr
[  OK  ] DietPi-Services | restart : docker
[  OK  ] DietPi-Services | restart : cron
Dietpi-Services still unmask and stop mariadb that shouldnt really exist. And after all I receive failed mariadb service :(
MichaIng wrote: Wed Mar 03, 2021 3:37 pm The CLI issue was fixed with: https://github.com/MichaIng/DietPi/comm ... 10eb912271
Hi @MichaIng, I'm glad that I could somehow help with finding this issue and thank you so much for mentioning me in changelog :o :D Still learning stuff so this is kind of new for me.
As you see I still have some problems and I'm not sure if I should maybe reinstall whole system and start from zero, because this looks like I messed up something and somehow at some point and now I'm wasting your time.
Could you tell me for what would I even need MariaDB? It is needed only for Nextcloud in my situation? Tbh I want to install in near future Nextcloud again after I finish setting up HA Supervisor in Docker.
Re: MariaDB error
looking to your services, it seems MariaDB is used on NextCloud only. Before going to kill you system and start from scratch, one last try to setup the database :)
G_AGA
mkdir /mnt/dietpi_userdata/mysql
apt install mariadb-server
Re: MariaDB error
Yes, like in the other issue, purging the actual MariaDB server packages was missing (hence the still active service). "mariadb-server" is just a dummy package that pulls in mariadb-server-10.3, the actual server package on Debian/Raspbian Buster.
But installing it again is not necessary if Nextcloud is not used anymore? Or just to do a clean uninstall of both?
Otherwise, to remove all traces manually, after the packages have been purged and autopurged (G_AGA):
rm -Rf /var/www/nextcloud /mnt/dietpi_userdata/nextcloud_data
sed -i '/aSOFTWARE_INSTALL_STATE\[88\]/c\aSOFTWARE_INSTALL_STATE\[88\]=0' /boot/dietpi/.installed
sed -i '/aSOFTWARE_INSTALL_STATE\[114\]/c\aSOFTWARE_INSTALL_STATE\[114\]=0' /boot/dietpi/.installed
Zeuskk
Re: MariaDB error
Post by Zeuskk »
MichaIng wrote: Thu Mar 04, 2021 3:37 pm Yes, like in the other issue, purging the actual MariaDB server packages was missing (hence the still active service). "mariadb-server" is just a dummy package that pulls in mariadb-server-10.3, the actual server package on Debian/Raspbian Buster.
Yesss, this finally helped me :) I get rid of MariaDB and Failed service status. Now system is prepared for future clean Nextcloud install (I hope so haha ;) ). Thank you very much @MichaIng and @Joulinar for help and sorry for late replay. Cheers!
Re: MariaDB error
ok perfect that it is working now
