uname -a
qBittorrent not downloading Topic is solved
Re: qBittorrent not downloading
it's a 64bit system right?
ok let me test on a 64bit demo system. The guide on qBittorrent is based on 32bit system if I'm not mistaken
it's basically working as well for 64bit. At least on my RPi 64bit test system
I changed the
that's what I did on an empty system (copied from my command line history
for the service I used following definition
I changed the
./configure
lines on the guidethat's what I did on an empty system (copied from my command line history
apt install build-essential pkg-config automake libtool libc6-dev libboost-dev libboost-system-dev libboost-chrono-dev libboost-random-dev libssl-dev qtbase5-dev qttools5-dev-tools libqt5svg5-dev zlib1g-dev
cd /tmp/
wget https://github.com/arvidn/libtorrent/archive/v1.2.12.zip
unzip v1.2.12.zip
cd libtorrent-1.2.12/
./autotool.sh
./configure --disable-debug --enable-encryption --with-boost-libdir=/usr/lib/aarch64-linux-gnu --with-libiconv CXXFLAGS="-std=c++17"
make -j$(nproc)
sudo make install
cd ..
sudo nano /etc/ld.so.conf.d/libtorrent.conf
## add following and save file: /usr/local/lib
sudo ldconfig
export LD_LIBRARY_PATH=/usr/local/lib:${LD_LIBRARY_PATH}
wget https://github.com/qbittorrent/qBittorrent/archive/release-4.3.3.zip
unzip release-4.3.3.zip
cd qBittorrent-release-4.3.3/
./configure --disable-gui --enable-systemd --with-boost-libdir=/usr/lib/aarch64-linux-gnu CXXFLAGS="-std=c++17"
make -j$(nproc)
sudo make install
sudo useradd -rm qbittorrent -G dietpi -s /usr/sbin/nologin
nano /etc/systemd/system/qbittorrent.service
## add service definition and save file
systemctl daemon-reload
systemctl start qbittorrent
systemctl status qbittorrent
reboot
journalctl -u qbittorrent.service
[Unit]
Description=qBittorrent (DietPi)
Documentation=man:qbittorrent-nox(1)
Wants=network-online.target
After=network-online.target dietpi-boot.service
[Service]
User=qbittorrent
UMask=002
ExecStart=/usr/local/bin/qbittorrent-nox
[Install]
WantedBy=multi-user.target
Wow this has blocked the odroid, had to reset itJoulinar wrote: ↑Mon Feb 15, 2021 1:25 pm it's basically working as well for 64bit. At least on my RPi 64bit test system
I changed the./configure
lines on the guide
that's what I did on an empty system (copied from my command line history)
for the service I used following definitionCode: Select all
apt install build-essential pkg-config automake libtool libc6-dev libboost-dev libboost-system-dev libboost-chrono-dev libboost-random-dev libssl-dev qtbase5-dev qttools5-dev-tools libqt5svg5-dev zlib1g-dev cd /tmp/ wget https://github.com/arvidn/libtorrent/archive/v1.2.12.zip unzip v1.2.12.zip cd libtorrent-1.2.12/ ./autotool.sh ./configure --disable-debug --enable-encryption --with-boost-libdir=/usr/lib/aarch64-linux-gnu --with-libiconv CXXFLAGS="-std=c++17" make -j$(nproc) sudo make install cd .. sudo nano /etc/ld.so.conf.d/libtorrent.conf ## add following and save file: /usr/local/lib sudo ldconfig export LD_LIBRARY_PATH=/usr/local/lib:${LD_LIBRARY_PATH} wget https://github.com/qbittorrent/qBittorrent/archive/release-4.3.3.zip unzip release-4.3.3.zip cd qBittorrent-release-4.3.3/ ./configure --disable-gui --enable-systemd --with-boost-libdir=/usr/lib/aarch64-linux-gnu CXXFLAGS="-std=c++17" make -j$(nproc) sudo make install sudo useradd -rm qbittorrent -G dietpi -s /usr/sbin/nologin nano /etc/systemd/system/qbittorrent.service ## add service definition and save file systemctl daemon-reload systemctl start qbittorrent systemctl status qbittorrent reboot journalctl -u qbittorrent.service
[Unit] Description=qBittorrent (DietPi) Documentation=man:qbittorrent-nox(1) Wants=network-online.target After=network-online.target dietpi-boot.service [Service] User=qbittorrent UMask=002 ExecStart=/usr/local/bin/qbittorrent-nox [Install] WantedBy=multi-user.target
I am trying again with just installing Mate desktop and qbittorrent, but I faced the problem with the login in qbittorrent webadmin, that the password is not correct, isn't this fixed as I read on github? I don't remember what I did to reset the password...
P.D: nothing still the same no connection on udp trackers.. With just installing qbittorrent and Mate desktop..
P. D. 2.: I was able to do all the steps to update but when I open qbittorrent still shows 4.1.5 version... I didn't see any error during the update process
I install full qbittorrent not the Web ui included on dietpi and happens the same..
on a fresh compiled installation, password is the qBittorrent default one usually
Ok, found a problem.. when Nat acceleration on Asus router is enabled, is when I can't download from qbittorrent, if I disabled the downloads start.
This affects only to qbittorrent on linux, on windows there is no problem.., so is not a problem of Dietpi
Thank you for your help and time.
