wireguard service won't start after update Topic is solved
sesamzoo
Re: wireguard service won't start after update
Post by sesamzoo »
Joulinar wrote: Tue Jul 14, 2020 11:46 am Yes using STATIC IP will be faster than DHCP to get network interface up.
@Joulinar and @jollyrogr, using STATIC IP might be faster but it doesn't guarantee that the issue won't happen then.
In my case adding
PreUp = /boot/dietpi/func/obtain_network_details
was required to start Wireguard after bootup in a STATIC IP scenario.
The error reminded me on this issue: viewtopic.php?f=11&t=6302 (Github: https://github.com/MichaIng/DietPi/issu ... -544679670)
For new installations, the issue was fixed with current DietPi version 6.31
https://github.com/MichaIng/DietPi/comm ... 3b7b9df327
