Fourdee
Posts: 2781 Joined: Tue Feb 06, 2007 1:36 pm
Post
by Fourdee » Thu Jul 07, 2016 9:21 pm
RasPiHacker wrote: Hi Fourdee!
Have been hospitalized for two weeks, just seen Your post today.
I have tried all the other suggestions in the forums regarding update problems on the V.115, but none has worked.
dietpi-update with no or any option (1,2,3) returns the same error:
DietPi-Update:
Checking for DietPi updates, Please wait...
curl: (3) Illegal characters found in URL
cat /DietPi/dietpi.txt | grep 'git'
returns this:
root@DietPiZero:~# cat /DietPi/dietpi.txt | grep 'git'
gitbranch=master
root@DietPiZero:~#
Sincerely
RasPiHacker
Hi RasPiHacker,
No worries, hopefully your onto a good recovery?
The inability to update is most likely the line endings in dietpi.txt being dos, instead of unix. This can occur when a user edits the file on a Windows PC with notepad/wordpad.
To resolve this, please run the folllowing commands, as per this post:
https://github.com/Fourdee/DietPi/issue ... -228723958
sed -i $'s/\r$//' /DietPi/dietpi.txt
dietpi-update
Please let me know the results
Donating is the easiest – you can use PayPal or become a DietPi patron .
RasPiHacker
Post
by RasPiHacker » Thu Jul 07, 2016 9:38 pm
Hi again.
I had tried everything in this thread:
Raspberry Pi 3 wont update , but noting worked.
Running the above fixed it, thank You Fourdee!
Strange since I have not used anything but Putty to connect via serial cable to the Zero, and nano, once logged in, to edit files on the Zero.
Anyways:
DietPi | 21:29 | Thu 07/07/16
V122 | RPi Zero (armv6l)
IP Address | 192.168.30.49
It works a treat now, thank You again and keep up the good work!!
Sincerely
RasPiHaker
