Autostart with LXDE + VNC4 (SOLVED)
Facel
Re: Autostart with LXDE + VNC4 (Solved)
Post by Facel »
Sorry ..... dietpi was already an existing user (I did not know)
I have followed your last email but the problem is still there (The authentification failed)
$ cd /home/dietpi/ && vncserver -rfbauth /home/dietpi/.vnc/passwd :1 -geometry 1024x768 -depth 24" 2>/dev/null &
=> does not generate any password, it only prompt a ">"
The /etc/rc.local file cannot be modified when I am logged as dietpi, I must be logged as root in order to be able to modify it
WarHawk
Post by WarHawk »
Right the ownership level of /etc/rc.local is 755 only root can modify, everyone can read
sorry I forgot to clarify
I always create a login of a user not already on the system...apologies for the confusion
Anyone else want to join the fray?
Facel
Post by Facel »
Griffon web site saved me ....
I have followed his advices http://c-nergy.be/blog/?p=10426 and it is finally running.
@WarHawk => Thanks again for your help that definitivly helped me understanding part of the linux world
WarHawk
Post by WarHawk »
Facel wrote:Griffon web site saved me ....
Awesome..thanks!
winston65
Re: Autostart with LXDE + VNC4 (SOLVED)
Post by winston65 »
My dietpi launcher will not load the list that I can install desktop from. I've tried several times. That menu choice is not not there. Tired of trying, gonna move to something else
did you tried using dietpi-software ??
