Fourdee
Posts: 2779 Joined: Tue Feb 06, 2007 1:36 pm
Post
by Fourdee » Sat Feb 04, 2017 6:21 pm
mike175de wrote: Hi Fourdee,
here we go
Michael
Hi Michael,
Thanks. Time spent at idle and full load seems reasonable.
I think the majority of usage is from /usr/sbin/smbd (Samba server). Samba can be CPU intensive, try copying a file to (or from) the server and check cpu frequency with:
echo -e $(( $(cat /sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq) / 1000 ))
Might be an idea to check temp now and then (as above command may trigger a frequency up step) with:
You could also rerun this test for 30 minutes and see if the time spent in idle improves, after disabling one service at a time:
Disable samba:
systemctl stop smbd
systemctl stop nmbd
Disable dnsmasq:
Donating is the easiest – you can use PayPal or become a DietPi patron .
mike175de
Posts: 67 Joined: Sat Sep 05, 2015 4:39 pm
Post
by mike175de » Sat Feb 04, 2017 8:41 pm
Ho Fourdee,
I copied a large file (1,4GB) to the samba-server. The results of
cpu were this:
root@dietpiserver:~# echo -e $(( $(cat /sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq) / 1000 ))
1000
root@dietpiserver:~# cpu
DietPi CPU Info
Use dietpi-config to change CPU / performance options
Architecture | armv7l
Temp | 59'c | Running warm, but safe.
Governor | ondemand
Throttle up | 85% CPU usage
Current Freq Min Freq Max Freq
CPU0 | 600 MHz 200 MHz 1400 MHz
CPU1 | 800 MHz 200 MHz 1400 MHz
CPU2 | 800 MHz 200 MHz 1400 MHz
CPU3 | 700 MHz 200 MHz 1400 MHz
CPU4 | 1100 MHz 200 MHz 2000 MHz
CPU5 | 1100 MHz 200 MHz 2000 MHz
CPU6 | 1000 MHz 200 MHz 2000 MHz
CPU7 | 1000 MHz 200 MHz 2000 MHz
DietPi CPU Info
Temp | 60'c | Running hot, not recommended.
Governor | ondemand
CPU0 | 700 MHz 200 MHz 1400 MHz
CPU1 | 700 MHz 200 MHz 1400 MHz
CPU2 | 700 MHz 200 MHz 1400 MHz
CPU4 | 1200 MHz 200 MHz 2000 MHz
CPU5 | 1200 MHz 200 MHz 2000 MHz
CPU6 | 1200 MHz 200 MHz 2000 MHz
CPU7 | 1200 MHz 200 MHz 2000 MHz
DietPi CPU Info
Governor | ondemand
CPU1 | 600 MHz 200 MHz 1400 MHz
CPU3 | 600 MHz 200 MHz 1400 MHz
CPU4 | 1000 MHz 200 MHz 2000 MHz
CPU5 | 1000 MHz 200 MHz 2000 MHz
DietPi CPU Info
Governor | ondemand
CPU0 | 1400 MHz 200 MHz 1400 MHz
CPU1 | 1400 MHz 200 MHz 1400 MHz
CPU2 | 1400 MHz 200 MHz 1400 MHz
CPU3 | 1400 MHz 200 MHz 1400 MHz
CPU6 | 1100 MHz 200 MHz 2000 MHz
CPU7 | 1100 MHz 200 MHz 2000 MHz
DietPi CPU Info
Governor | ondemand
CPU7 | 900 MHz 200 MHz 2000 MHz
DietPi CPU Info
Governor | ondemand
CPU0 | 400 MHz 200 MHz 1400 MHz
CPU2 | 600 MHz 200 MHz 1400 MHz
CPU6 | 500 MHz 200 MHz 2000 MHz
CPU7 | 500 MHz 200 MHz 2000 MHz
DietPi CPU Info
Governor | ondemand
CPU4 | 900 MHz 200 MHz 2000 MHz
CPU5 | 900 MHz 200 MHz 2000 MHz
CPU6 | 900 MHz 200 MHz 2000 MHz
DietPi CPU Info
Governor | ondemand
DietPi CPU Info
Governor | ondemand
CPU4 | 1300 MHz 200 MHz 2000 MHz
CPU5 | 1300 MHz 200 MHz 2000 MHz
CPU6 | 1300 MHz 200 MHz 2000 MHz
CPU7 | 1300 MHz 200 MHz 2000 MHz
DietPi CPU Info
Governor | ondemand
DietPi CPU Info
Governor | ondemand
DietPi CPU Info
Governor | ondemand
CPU3 | 800 MHz 200 MHz 1400 MHz
DietPi CPU Info
Governor | ondemand
DietPi CPU Info
Temp | 61'c | Running hot, not recommended.
Governor | ondemand
DietPi CPU Info
Governor | ondemand
CPU0 | 800 MHz 200 MHz 1400 MHz
DietPi CPU Info
Governor | ondemand
DietPi CPU Info
Governor | ondemand
As you can see there were all kind of states presents. Maybe i stick with the ondemandgov and throttle all the cpus to 1400Mhz?
Thx again, Michael
Fourdee
Post
by Fourdee » Sun Feb 05, 2017 3:14 pm
Thx again, Michael
Hi Michael,
Thanks, yep, I believe its just a case of background services peaking CPU load. As the XU4 runs really hot, even at low loads, I think that may be the sudden rise in temps.
The CPU time in your ps aux post seems fine, nothing out of the ordinary that would indicate a program/process constantly using CPU.
It only takes around 2 seconds to reach 90'c+ at full load on this device. Capping the frequencies is recommended, I cap mine at 1.5GHz, seems to stay under 70'c.
Another option is heatsink upgrade, or, pop it in the freezer
lol
mike175de
Post
by mike175de » Sun Feb 05, 2017 4:50 pm
Hi Fourdee,
thx again.
Yep, I will stay with 1,5GHz as well. Until now the device is under 60 Degress. I'm fine with that
Michael
BTW: Just sad that the XU4 is the only device with a good CPU and USB3. Maybe in th near future someone like FriendlyArm build one also with USB3 and a "better" CPU.
