Update | RPi Stretch image is now default with DietPi v159
Fourdee
Re: RPi Stretch (Alpha) | testers wanted
Post by Fourdee »
The_Raven wrote:Is it still "alpha"? Or beta maybe rc?
Is there a date for the final?
Beta. Final when all software titles are functional (eg: kodi outstanding):
https://github.com/Fourdee/DietPi/issue ... -171250292
The_Raven
Re: RPi Stretch (Beta) | testers wanted
Post by The_Raven »
Thx for answering and changing the title to beta. Alpha sounds a bit scary :lol:
Fourdee
Post by Fourdee »
The_Raven wrote:Thx for answering and changing the title to beta. Alpha sounds a bit scary :lol:
Hehe, :)
When we use the word "Alpha", its probably more stable than "Release", abused by most Xbox/PS games. We're "old school" ;)
The_Raven
Post by The_Raven »
Installation of motioneye fails.
E: Unable to locate package libx264-142
E: Package 'libavcodec56' has no installation candidate
E: Package 'libavformat56' has no installation candidate
E: Package 'libmysqlclient18' has no installation candidate
E: Unable to locate package libswscale3
 [Failed] The apt cache may be corrupt, apt mirror offline, or you have held broken packages. DietPi-Software will now exit.
It searchs for "libx264-142", but available is "libx264-148" or "libx264".
And "libavcodec56" should be "libavcodec57" i think (same for "libavformat").
"libmysqlclient18" -> ???
"libswscale3" -> ???
Fourdee
Post by Fourdee »
The_Raven wrote:Installation of motioneye fails.
Thanks for the report, we'll investigate:
https://github.com/Fourdee/DietPi/issues/1155
Bridouz
Post by Bridouz »
Thanks a lot for DietPi first. It's a really nice piece of code to make my Rpi3 smooth and fast.
I'm ready to test a lot to improve DietPi.
The_Raven
Post by The_Raven »
MotionEye seems to be fixed now! Great job! 8-)
But sorry i found other bugs... :?
The WiFi is buggy.
1. If you change the wifi settings and press "apply", it does not work and shows an error "invalid argument" (see picture, this is the WiFi-Key).
But after a restart it works.
2. If the WiFi connection is lost, it does not reconnect. So far so good. For this there is the option "Auto Reconnect".
But after selecting this, the WiFi is not able to connect anymore at all! Sometimes on reboot you have WiFi for a short time, but then it drops.
Can someone confirm this bugs?
pakikje
Post by pakikje »
Can i test some on a Orange Pi plus?
ps: off topic. I am very happy with DietPi and homeassistant! (i can finally place images of my webcams/ip-cams on a webpage in DietPi)
baz123
Post by baz123 »
Is it possible to get a VMWARE img please?
Fourdee
Post by Fourdee »
baz123 wrote:Is it possible to get a VMWARE img please?
http://dietpi.com/downloads/images/Diet ... tretch).7z
Also on our main website, under downloads for PC/VM
