Cannot mount USB drive
Re: Cannot mount USB drive
Okay, at least now fsck.ext4 is correctly invoked, previously it showed fsck.ext2. The read-only is on a different level, because fsck doesn't require a filesystem to be mounted at all. [sda] Write Protect is on sounds like the drive itself is somehow write protected, but not sure if this is still due to filesystem or partition table corruption :?.
Can you try:
hdparm -r0 /dev/sda
fsck /dev/sda1
sfh1975
Post by sfh1975 »
MichaIng wrote: Tue Oct 12, 2021 2:27 pm Okay, at least now fsck.ext4 is correctly invoked, previously it showed fsck.ext2. The read-only is on a different level, because fsck doesn't require a filesystem to be mounted at all. [sda] Write Protect is on sounds like the drive itself is somehow write protected, but not sure if this is still due to filesystem or partition table corruption :?.
Can you try:
hdparm -r0 /dev/sda
fsck /dev/sda1
Thanks, I read somewhere that if the drive is failing or encounters errors, the system marks it as read-only. Anyway, here is the rather strange result of your suggestion :(
root@DietPi:~# root@DietPi:~# hdparm -r0 /dev/sda
/dev/sda:
setting readonly to 0 (off)
readonly = 0 (off)
root@DietPi:~# fsck /dev/sda1
fsck from util-linux 2.33.1
e2fsck 1.44.5 (15-Dec-2018)
fsck.ext4: Read-only file system while trying to open /dev/sda1
Disk write-protected; use the -n option to do a read-only
check of the device.
sfh1975
Post by sfh1975 »
Also,
root@DietPi:~# cat /var/log/messages
Oct 12 23:35:54 DietPi kernel: [ 6568.733260] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
trendy
Post by trendy »
Try to do the filesystem check on the Ubuntu. Remember not to mount the stick upon connecting it.
What I know is that a mounted filesystem is re-mounted as read-only, when critical filesystem errors are found, but I didn't see this kind of write-protection yet that blocks all kind of writes outside of the mount. hdparm -r allows to set/unset a device-level read-only flag, but obviously that either was not the case of reverted directly.
Yes makes sense to try it on a different system. Next would be to try rewriting the partition table, if not prevented for the same reason.
sfh1975
Post by sfh1975 »
Thanks everyone. Well the result is the same. Ubuntu also recognizes the USB as in need of repair but it can neither mount it nor can it remove the read-only flag :( Seems like quite a few people had this issue but with little success. Most cases just ended up formatting the USB.
Is there any way I can salvage the data from it? Or is there a possibility of a backup of userdata might be in Dietpi?
Thank you and looking for suggestions.
trendy
Post by trendy »
You could try to make a dump of the usb stick with dd.
Then try to mount the image as a loop device and copy what you can salvage.
Good idea, probably a loop device does not suffer from such read-only flag. Whether it can then be mounted is another question, but probably it can be repaired (fsck) then.
