64 bit install no off LAN access
Re: 64 bit install no off LAN access
And you had activated HTTPS for all of them individually? Or did you hab a reverse proxy running?
boogey
Post by boogey »
I found out what the problem likely is. For testing my off-LAN connectivity, I used my cell phone. I found out today that my cell network is experiencing connectivity issues. I think everything was likely running fine and that I was overly tired and trying to push through. Thanks for the help Joulinar! Wasn't making any sense at all, I know. Until next time!
Something things like this happen and you are going to hunt a ghost. 8)
