Some reinstalls of software after upgrade from Buster to Bullseye fail Topic is solved
fhals
Re: Some reinstalls of software after upgrade from Buster to Bullseye fail
Post by fhals »
Sudo user should by 'mysql', not 'mariadb', right?
sudo -u mariadb /usr/sbin/mariadbd
sudo: unknown user: mariadb
sudo: error initializing audit plugin sudoers_audit
Already tried this without sudo with the same result:
sudo -u mysql /usr/sbin/mariadbd
Illegal instruction
Yes user is mysql
Hmm looks like the binary is broken :?
Maybe reinstall would be the way to go
fhals
Post by fhals »
Reinstalling is where the trouble started.
Now, when I reinstall mariadb only, it goes well, but starting the service fails. (lighttpd and ncc too).
When I use the combined reinstall as suggested in the bullseye upgrade hint (dietpi-software reinstall 38 40 47 48 56 83 84 85 88 89 93 114 143), the latter services startup fine, just mariadb fails.
dietpi-software reinstall 88
[  OK  ] DietPi-Software | Initialised database
[  OK  ] DietPi-Software | Reading database
 DietPi-Software
 Mode: Automated reinstall
[  OK  ] DietPi-Software | Reinstalling MariaDB: Persistent cached file-per-table database server
[  OK  ] DietPi-Software | Free space check: path=/ | available=4179 MiB | required=500 MiB
[  OK  ] DietPi-Software | DietPi-Userdata validation: /mnt/usb_1/dietpi_userdata
[  OK  ] DietPi-Software | Checking network connectivity
[  OK  ] DietPi-Software | Checking DNS resolver
[  OK  ] Network time sync | Completed
[ SUB1 ] DietPi-Services > unmask
[  OK  ] DietPi-Services | unmask : nmbd
[  OK  ] DietPi-Services | unmask : smbd
[  OK  ] DietPi-Services | unmask : redis-server
[  OK  ] DietPi-Services | unmask : mariadb
[  OK  ] DietPi-Services | unmask : postgresql
[  OK  ] DietPi-Services | unmask : php7.4-fpm
[  OK  ] DietPi-Services | unmask : lighttpd
[  OK  ] DietPi-Services | unmask : jellyfin
[  OK  ] DietPi-Services | unmask : cron
[ SUB1 ] DietPi-Services > stop
[  OK  ] DietPi-Services | stop : cron
[  OK  ] DietPi-Services | stop : jellyfin
[  OK  ] DietPi-Services | stop : lighttpd
[  OK  ] DietPi-Services | stop : php7.4-fpm
[  OK  ] DietPi-Services | stop : postgresql
[  OK  ] DietPi-Services | stop : mariadb
[  OK  ] DietPi-Services | stop : redis-server
[  OK  ] DietPi-Services | stop : smbd
[  OK  ] DietPi-Services | stop : nmbd
[  OK  ] DietPi-Software | mkdir -p /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads /var/www /opt /usr/local/bin
[  OK  ] DietPi-Software | chown dietpi:dietpi /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads
[  OK  ] DietPi-Software | chmod 0775 /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads
[ INFO ] DietPi-Software | APT update, please wait...
Hit:1 https://deb.debian.org/debian bullseye InRelease
Hit:2 https://dietpi.com/meveric all InRelease
Get:3 https://deb.debian.org/debian bullseye-updates InRelease [39.4 kB]
Hit:4 https://dietpi.com/meveric bullseye InRelease
Hit:5 https://deb.debian.org/debian-security bullseye-security InRelease
Get:6 https://deb.debian.org/debian bullseye-backports InRelease [40.9 kB]
Get:7 https://repo.jellyfin.org/debian bullseye InRelease [6639 B]
Fetched 86.9 kB in 3s (29.1 kB/s)
Reading package lists...
[  OK  ] DietPi-Software | APT update
 DietPi-Software
 Step: Checking for prerequisite software
 DietPi-Software
 Step: Installing MariaDB: Persistent cached file-per-table database server
[ INFO ] DietPi-Software | Preparing database directory at: /mnt/dietpi_userdata/mysql
[ INFO ] DietPi-Software | /mnt/dietpi_userdata/mysql exists, will migrate containing databases
[  OK  ] DietPi-Software | rm -Rf /var/lib/mysql
[  OK  ] DietPi-Software | ln -s /mnt/dietpi_userdata/mysql /var/lib/mysql
[ INFO ] DietPi-Software | APT install for: mariadb-server php7.4-mysql, please wait...
[  OK  ] DietPi-Software | APT install for: mariadb-server php7.4-mysql
[ INFO ] DietPi-Software | Removing obsolete SysV mysql service
[  OK  ] DietPi-Software | update-rc.d mysql remove
 DietPi-Software
 Step: Finalising install
[  OK  ] DietPi-Software | systemctl daemon-reload
[ SUB1 ] DietPi-Services > dietpi_controlled
[  OK  ] DietPi-Services | dietpi_controlled : nmbd
[  OK  ] DietPi-Services | dietpi_controlled : smbd
[  OK  ] DietPi-Services | dietpi_controlled : redis-server
[  OK  ] DietPi-Services | dietpi_controlled : mariadb
[  OK  ] DietPi-Services | dietpi_controlled : postgresql
[  OK  ] DietPi-Services | dietpi_controlled : php7.4-fpm
[  OK  ] DietPi-Services | dietpi_controlled : lighttpd
[  OK  ] DietPi-Services | dietpi_controlled : jellyfin
[  OK  ] DietPi-Services | dietpi_controlled : cron
 DietPi-Software
 Step: Install completed
[  OK  ] DietPi-Survey | Purging survey data
[ SUB1 ] DietPi-Services > restart
[  OK  ] DietPi-Services | restart : nmbd
[  OK  ] DietPi-Services | restart : smbd
[  OK  ] DietPi-Services | restart : redis-server
[FAILED] DietPi-Services | restart : mariadb
[  OK  ] DietPi-Services | restart : postgresql
[  OK  ] DietPi-Services | restart : php7.4-fpm
[FAILED] DietPi-Services | restart : lighttpd
[  OK  ] DietPi-Services | restart : jellyfin
[  OK  ] DietPi-Services | restart : cron
[FAILED] DietPi-Services | ncc maintenance:mode --off
You have a database backup available right?
I guess you would need to force a reinstallation using
apt install --reinstall mariadb-server
fhals
Post by fhals »
Wish it would help:
# apt install --reinstall mariadb-server
Reading package lists... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 34.8 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 https://deb.debian.org/debian bullseye/main arm64 mariadb-server all 1:10.5.11-1 [34.8 kB]
Fetched 34.8 kB in 0s (98.0 kB/s)
(Reading database ... 35151 files and directories currently installed.)
Preparing to unpack .../mariadb-server_1%3a10.5.11-1_all.deb ...
Unpacking mariadb-server (1:10.5.11-1) over (1:10.5.11-1) ...
Setting up mariadb-server (1:10.5.11-1) ...
At the end, I can't restart mariadb.service. Like before, without any useful error message.
Hmm in this case we might need to purge and remove everything related to mariadb otherwise I'm not sure how to fix but definitely you need a backup from before.
nigelf
Post by nigelf »
simply to echo what fhals has been experiencing.
I have tried reinstalls both of entire LEMP package & Mariadb on its own. I have renamed & recreated all configuration folders but still have no luck. DietPi v7.6.2 (beta) with all upgrades done. I have no useful information to add - similar messages & lack of error.log.
fhals
Post by fhals »
I made a full dump of all databases prior upgrade to bullseye, so I'll be happy to volunteer.
What would be the best way to purge/delete/install without killing my nextcloud from being restored?
Basically this should fully remove everything related to MariaDB
viewtopic.php?p=32301&sid=08849092ffcad ... dd7#p32301
Afterwards a reinstall of Nextcloud would be needed to setup database again. If SQL dump is present, it should be imported automatically.
Usually Nextcloud files should stay untouched. But let's wait for @MichaIng to confirm best way.
nigelf
Post by nigelf »
I did:
G_AGP mariadb-server
G_AGA
sed -i '/aSOFTWARE_INSTALL_STATE\[88\]/c\aSOFTWARE_INSTALL_STATE\[88\]=0' /boot/dietpi/.installed
rm -Rf /{mnt/dietpi_userdata,var/lib,var/log,etc}/mysql
mkdir /mnt/dietpi_userdata/mysql
apt install mariadb-server
systemctl status mariadb
...but no change:
'Job for mariadb.service failed because a fatal signal was delivered to the control process'
