apache2ctl Topic is solved
Re: apache2ctl
you are going to execute the command as non-root user. Therefore path variable is missing full path to apache2ctl
Pls try sudo apache2ctl as current user or use user root
Re: apache2ctl
Ahh, that's the mystery. Good to keep in mind that sbin directories are not in the PATH when doing interactive shell sessions with non-root users.
Burgess85
Re: apache2ctl
Post by Burgess85 »
MichaIng wrote: Tue Sep 21, 2021 6:48 pm Ahh, that's the mystery. Good to keep in mind that sbin directories are not in the PATH when doing interactive shell sessions with non-root users.
Magic! Cheers
