problem while trying to upgrade to Bullseye following your blog post Topic is solved
Re: problem while trying to upgrade to Bullseye following your blog post
hmm on RealVNC I was not able to replicate the behaviour. For me it was working on 7.5 without issues.
manilx
Post by manilx »
Joulinar wrote: Mon Aug 30, 2021 12:01 am hmm on RealVNC I was not able to replicate the behaviour. For me it was working on 7.5 without issues.
Tried this on the 2 pie’s. Uninstalled tiger installed real. Tried to connect to port 5900 and no go.
pls share again once RealVNC is installed
journalctl -u vncserver.service
ss -tulpn | grep LISTEN
manilx
Post by manilx »
Joulinar wrote: Mon Aug 30, 2021 10:03 am pls share again once RealVNC is installed
Ok, tested again.
Uninstalled working TigerVNC (after the mod of the config file). Installed realVNC. Tried connecting to port 5900.
Could not connect.
root@Unify:~# journalctl -u vncserver.service
Journal file /var/log/journal/9290cc6d05c648b1ad37b19873f26fd1/system.journal is truncated, ignoring file.
-- Journal begins at Mon 2021-08-30 08:50:50 WEST, ends at Mon 2021-08-30 09:07:49 WEST. --
Aug 30 08:51:15 Unify systemd[1]: Started Manage VNC Server (DietPi).
Aug 30 08:51:15 Unify systemd[666]: pam_unix(login:session): session opened for user root(uid=0) by (uid=0)
Aug 30 09:05:52 Unify systemd[1]: Stopping Manage VNC Server (DietPi)...
Aug 30 09:05:52 Unify systemd[5221]: pam_unix(login:session): session opened for user root(uid=0) by (uid=0)
Aug 30 09:05:52 Unify vncserver[5221]: [FAILED] No supported VNC server installed
Aug 30 09:05:52 Unify systemd[1]: vncserver.service: Control process exited, code=exited, status=1/FAILURE
Aug 30 09:05:52 Unify systemd[1]: vncserver.service: Failed with result 'exit-code'.
Aug 30 09:05:52 Unify systemd[1]: Stopped Manage VNC Server (DietPi).
Aug 30 09:07:49 Unify systemd[1]: Started Manage VNC Server (DietPi).
Aug 30 09:07:49 Unify systemd[6984]: pam_unix(login:session): session opened for user root(uid=0) by (uid=0)
Aug 30 09:07:49 Unify systemd[1]: vncserver.service: Main process exited, code=exited, status=1/FAILURE
Aug 30 09:07:49 Unify systemd[1]: vncserver.service: Failed with result 'exit-code'.
tcp   LISTEN 0      4096                  0.0.0.0:10000      0.0.0.0:*    users:(("miniserv.pl",pid=6966,fd=5))
tcp   LISTEN 0      1024        192.168.1.51%eth0:25552      0.0.0.0:*    users:(("zerotier-one",pid=552,fd=17))
tcp   LISTEN 0      1024        192.168.1.51%eth0:25553      0.0.0.0:*    users:(("zerotier-one",pid=552,fd=19))
tcp   LISTEN 0      128                 127.0.0.1:28017      0.0.0.0:*    users:(("mongod",pid=337,fd=10))
tcp   LISTEN 0      128                   0.0.0.0:22         0.0.0.0:*    users:(("sshd",pid=668,fd=3))
tcp   LISTEN 0      4096                127.0.0.1:8125       0.0.0.0:*    users:(("netdata",pid=6428,fd=37))
tcp   LISTEN 0      4096             192.168.1.51:19999      0.0.0.0:*    users:(("netdata",pid=6428,fd=4))
tcp   LISTEN 0      1024        192.168.1.51%eth0:9993       0.0.0.0:*    users:(("zerotier-one",pid=552,fd=15))
tcp   LISTEN 0      1024                127.0.0.1:9993       0.0.0.0:*    users:(("zerotier-one",pid=552,fd=6))
tcp   LISTEN 0      128                 127.0.0.1:27017      0.0.0.0:*    users:(("mongod",pid=337,fd=9))
tcp   LISTEN 0      128                 127.0.0.1:27117      0.0.0.0:*    users:(("mongod",pid=2213,fd=7))
tcp   LISTEN 0      5                     0.0.0.0:5901       0.0.0.0:*    users:(("Xtigervnc",pid=707,fd=7))
tcp   LISTEN 0      100                         *:8880             *:*    users:(("java",pid=1054,fd=167))
tcp   LISTEN 0      100                         *:8080             *:*    users:(("java",pid=1054,fd=163))
tcp   LISTEN 0      128                      [::]:22            [::]:*    users:(("sshd",pid=668,fd=4))
tcp   LISTEN 0      100                         *:8443             *:*    users:(("java",pid=1054,fd=205))
tcp   LISTEN 0      4096                    [::1]:8125          [::]:*    users:(("netdata",pid=6428,fd=36))
tcp   LISTEN 0      50                          *:6789             *:*    users:(("java",pid=1054,fd=196))
tcp   LISTEN 0      1024                    [::1]:9993          [::]:*    users:(("zerotier-one",pid=552,fd=7))
tcp   LISTEN 0      100                         *:8843             *:*    users:(("java",pid=1054,fd=221))
tcp   LISTEN 0      5                        [::]:5901          [::]:*    users:(("Xtigervnc",pid=707,fd=8))
manilx
Post by manilx »
Here is the output from TigerVNC install and RealVNC install:
 DietPi-Software
 Mode: Uninstalling TigerVNC Server: desktop for remote connection
dbus-user-session set to automatically installed.
[ INFO ] DietPi-Software | APT purge for: tigervnc-* x11vnc realvnc-vnc-server, please wait...
(Reading database ... 111082 files and directories currently installed.)
Removing tigervnc-standalone-server (1.11.0+dfsg-2) ...
Removing libfile-readbackwards-perl (1.05-2) ...
Removing x11vnc (0.9.16-7) ...
Removing libvncserver1:armhf (0.9.13+dfsg-2) ...
Removing libvncclient1:armhf (0.9.13+dfsg-2) ...
Removing liblzo2-2:armhf (2.10-2) ...
Removing tk (8.6.11+1) ...
Removing tk8.6 (8.6.11-2) ...
Removing tcl (8.6.11+1) ...
Removing tcl8.6 (8.6.11+dfsg-1) ...
Removing libtk8.6:armhf (8.6.11-2) ...
Removing tigervnc-common (1.11.0+dfsg-2) ...
Removing libtcl8.6:armhf (8.6.11+dfsg-1) ...
Processing triggers for mailcap (3.69) ...
Processing triggers for libc-bin (2.31-13+rpi1) ...
(Reading database ... 110644 files and directories currently installed.)
Purging configuration files for tk8.6 (8.6.11-2) ...
Purging configuration files for tcl8.6 (8.6.11+dfsg-1) ...
Purging configuration files for tigervnc-standalone-server (1.11.0+dfsg-2) ...
Purging configuration files for tigervnc-common (1.11.0+dfsg-2) ...
[  OK  ] DietPi-Software | APT purge for: tigervnc-* x11vnc realvnc-vnc-server
Removed /etc/systemd/system/multi-user.target.wants/vncserver.service.
 DietPi-Software
 Mode: Finalise uninstall
[ INFO ] DietPi-Software | APT autopurge, please wait...
[  OK  ] DietPi-Software | APT autopurge
[  OK  ] DietPi-Software | systemctl daemon-reload
[  OK  ] DietPi-Software | Free space check: path=/ | available=54139 MiB | required=500 MiB
[  OK  ] DietPi-Software | DietPi-Userdata validation: /mnt/dietpi_userdata
[  OK  ] DietPi-Software | Checking network connectivity
[  OK  ] DietPi-Software | Checking DNS resolver
[  OK  ] Network time sync | Completed
[ SUB1 ] DietPi-Services > unmask
[  OK  ] DietPi-Services | unmask : netdata
[  OK  ] DietPi-Services | unmask : webmin
[  OK  ] DietPi-Services | unmask : cron
[ SUB1 ] DietPi-Services > stop
[  OK  ] DietPi-Services | stop : cron
[  OK  ] DietPi-Services | stop : webmin
[  OK  ] DietPi-Services | stop : netdata
[  OK  ] DietPi-Software | mkdir -p /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads /var/www /opt
[  OK  ] DietPi-Software | chown dietpi:dietpi /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads
[  OK  ] DietPi-Software | chmod 0775 /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads
[ INFO ] DietPi-Software | APT update, please wait...
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://download.zerotier.com/debian/bullseye bullseye InRelease
Hit:3 https://archive.raspberrypi.org/debian bullseye InRelease
Ign:5 https://download.webmin.com/download/repository sarge InRelease
Hit:4 https://dl.ubnt.com/unifi/debian stable InRelease
Hit:6 https://download.webmin.com/download/repository sarge Release
Reading package lists...
[  OK  ] DietPi-Software | APT update
 DietPi-Software
 Mode: Checking for prerequisite software
 DietPi-Software
 Mode: Installing RealVNC Server: desktop for remote connection
[ INFO ] DietPi-Software | APT install for: realvnc-vnc-server, please wait...
Selecting previously unselected package realvnc-vnc-server.
(Reading database ... 110636 files and directories currently installed.)
Preparing to unpack .../realvnc-vnc-server_6.7.4.43891_armhf.deb ...
Unpacking realvnc-vnc-server (6.7.4.43891) ...
Setting up realvnc-vnc-server (6.7.4.43891) ...
Updating /etc/pam.d/vncserver
Updating /etc/pam.conf... done
Looking for font path... not found.
Generating private key... done
Installed systemd unit for VNC Server in Service Mode daemon
Start or stop the service with:
  systemctl (start|stop) vncserver-x11-serviced.service
Mark or unmark the service to be started at boot time with:
  systemctl (enable|disable) vncserver-x11-serviced.service
Installed systemd unit for VNC Server in Virtual Mode daemon
  systemctl (start|stop) vncserver-virtuald.service
  systemctl (enable|disable) vncserver-virtuald.service
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for shared-mime-info (2.0-1) ...
[  OK  ] DietPi-Software | APT install for: realvnc-vnc-server
 DietPi-Software
 Mode: Configuring RealVNC Server: desktop for remote connection
[  OK  ] DietPi-Software | systemctl enable vncserver
[  OK  ] DietPi-Software | chmod +x /usr/local/bin/vncserver
[  OK  ] DietPi-Software | mkdir -p /root/.vnc
[  OK  ] DietPi-Software | chmod +x /root/.vnc/xstartup
[ SUB1 ] DietPi-Services > dietpi_controlled
[  OK  ] DietPi-Services | dietpi_controlled : netdata
[  OK  ] DietPi-Services | dietpi_controlled : webmin
[  OK  ] DietPi-Services | dietpi_controlled : cron
 DietPi-Software
 Mode: Installation completed
TigerVNC is running on port 5901. Are you sure you have it removed?
manilx
Post by manilx »
Joulinar wrote: Mon Aug 30, 2021 10:11 am TigerVNC is running on port 5901. Are you sure you have it removed?
See above.
manilx
Post by manilx »
┌─────────────────────────────────────────────────┤ DietPi-Software ├──────────────────────────────────────────────────┐
                            │ Use the spacebar to select the software you would like to remove:                                                    │
                            │    [ ] 0    OpenSSH Client: Feature-rich SSH, SFTP and SCP client                                                    │
                            │    [ ] 3    MC: midnight commander, powerful file manager                                                            │
                            │    [ ] 5    ALSA: Advanced Linux Sound Architecture        │
                            │    [ ] 6    X.Org X Server: aka X11 - X Window System implementation                                                 │
                            │    [ ] 10   iftop: displays bandwidth usage information                                                              │
                            │    [ ] 11   IPTraf: interactive colorful ip lan monitor                                                              │
                            │    [ ] 23   LXDE: ultra lightweight desktop        │
                            │    [ ] 65   Netdata: real-time performance monitoring        │
                            │    [ ] 67   Firefox: web browser for desktop        │
                            │    [ ] 103  DietPi-RAMlog: Makes /var/log a RAM disk, preserves file structure on reboot                             │
                            │    [ ] 105  OpenSSH Server: Feature-rich SSH server with SFTP and SCP support                                        │
                            │    [ ] 115  Webmin: web interface system management        │
                            │    [ ] 120  RealVNC Server: desktop for remote connection
try to remove every VNC software you have. Reboot. Ensure no VNC process running, install RealVNC.
manilx
Post by manilx »
Joulinar wrote: Mon Aug 30, 2021 10:14 am try to remove every VNC software you have. Reboot. Ensure no VNC process running, install RealVNC.
I don't have any VNC software running. Ay least I don't know which one.
I only installed Tiger and now Real.
Don't know what else to do.
