[SOLVED] Yup, another PADD + DietPi Question Topic is solved
Re: [SOLVED] Yup, another PADD + DietPi Question
@MichaIng
Correct. Question was for the screen blanking while using Chromium kiosk mode
dwr
Post by dwr »
No worries on this any longer. I switched to a 5in LCD (HDMI connected) Screen which allows me to setup screen blanking through /boot/config.txt and it works great. All is well in my kingdom!
Appreciate the support!
dwr - SpicyLimes.io
