Closed ports (or so it seems) Topic is solved
RollingDutch
Contact:
Re: Closed ports (or so it seems)
Post by RollingDutch »
Yes, that ip is correct for me.
Still my other problem stays. Can't SSH to it, router can 'see' it, but nothing more. :(
If even ping is not working, something wrong on the general connection. You are sure the IP address is not used twice on your network?
RollingDutch
Contact:
Yes, 100% sure.
RollingDutch
Contact:
Seems that there is a problem with this Pi Zero. Got hold of another one, and this one could be accessed right a way.
Returning the other one to Amazon.
ok good. will mark this as solved in this case.
