wifi drivers missing after update Topic is solved
valdragas
Re: wifi drivers missing after update
Post by valdragas »
Yes, exist:
root@DietPi:~# ls -l /usr/lib/dkms/dkms_autoinstaller
-rwxr-xr-x 1 root root 1635 Jan 15  2019 /usr/lib/dkms/dkms_autoinstaller
This is its content:
exec="/usr/sbin/dkms"
prog=${exec##*/}
test -f $exec || exit 0
[ -e /etc/sysconfig/$prog ] && . /etc/sysconfig/$prog
case "$1" in
    start)
                if [ -n "$2" ]; then
                        kernel="$2"
                else
                        kernel=`uname -r`
                fi
                log_daemon_msg "$prog: running auto installation service for kernel $kernel"
                dkms autoinstall --kernelver $kernel
                log_end_msg $?
        stop|restart|force-reload|status|reload)
                # There is no stop action, this and the 04 priority during stop is
                # added to make RHEL chkconfig happy.
                # Ignore others on debian/ubuntu too
        echo $"Usage: $0 {start}"
        exit 2
esac
Okay, I tracked down a bit where the error is coming from, and its the final dkms autoinstall call that is done: https://github.com/RPi-Distro/repo/issu ... -844059446
Strange that in the other case this did not happen, but the postinst script instead reached the point where it prints its warning (not affecting the exit code): https://github.com/MichaIng/DietPi/issues/4371
Removing the 64-bit modules will help, but only until the next kernel upgrade happens:
rm -R /lib/modules/5.10.17-v8+
apt upgrade
valdragas
Post by valdragas »
I have executed the indicated commands but I remain exactly the same
root@DietPi:~# rm -R /lib/modules/5.10.17-v8+
root@DietPi:~# apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
regards
I guess the WiFi driver would need to be reinstalled. Can you try following
modprobe rtl8812au
valdragas
Post by valdragas »
Done:
root@DietPi:~# modprobe rtl8812au
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/5.4.51-v7l+/modules.dep.bin'
modprobe: FATAL: Module rtl8812au not found in directory /lib/modules/5.4.51-v7l+
root@DietPi:~# modprobe rt2800
modprobe: FATAL: Module rt2800 not found in directory /lib/modules/5.4.51-v7l+
root@DietPi:~# modprobe rt2800usb
modprobe: FATAL: Module rt2800usb not found in directory /lib/modules/5.4.51-v7l+
probably the module needs to be build first. Let's check with @MichaIng :)
Installed kernel and loaded kernel are not the same. You need to reboot first. The kernel driver should be loaded automatically, but otherwise run modprobe rtl8812au after reboot then. The apt upgrade went through without error now, so that part is solved.
valdragas
Post by valdragas »
I have rebooted but things remain the same:
root@DietPi:~# uname -a
Linux DietPi 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l GNU/Linux
root@DietPi:~# uptime
 17:40:19 up 2 min,  2 users,  load average: 0.14, 0.19, 0.08
It is not a Berryboot image, is it?
Can you show the content of the boot partition and kernel modules:
ls -l /boot /lib/modules
@MichaIng
does the module would need to be build first using dkms. Something like
sudo dpkg-reconfigure rtl8812au
