Just tried out queezelite and airplay on the same raspberry pi.
Now with v138 is works perfectly on the same client device!!!
Thank you for fixing it so fast!
Amazing job!
384 kHz/32bit Kernel support
Re: 384 kHz/32bit Kernel support
With v138 update, now it is fixed - both squeezelte and shairport nicely coexist and play one after other on the same Raspberry Pi.
THANK YOU Fourdee for getting it fixed so prompt !
So if I somehow make Dietpi stick to the next newest kernel ( don't know how I could avoid the update, but I could play with that or if some of you had a quick idea) and upgrade to the 384 kernel, would it possible work also with the Allo Boss (for use with Roon?)
