ALSA equalizer not working Topic is solved
Re: ALSA equalizer not working
Very strange :?. When playing audio, only reading the equalizer control file should be sufficient and Raspotify shouldn't know about the control device to change the equalizer.
I have to run some tests with other players, I think.
Does the following work with 0644 permissions?
sudo -u raspotify speaker-test
