because anydesk does not finish updating correctly? Topic is solved
Re: because anydesk does not finish updating correctly?
Can you check the exit code:
/var/lib/dpkg/info/anydesk.postinst configure
echo $?
Actually I think I know where the issue is:
        command_exists update-menus && update-menus
        command_exists update-desktop-database && update-desktop-database
        command_exists xdg-desktop-menu && xdg-desktop-menu forceupdate
This means, if any of those commands does not exist, the scripts exits with an error code, as the last check returned a "false". It's a bug in the postinst script.
To verify:
command -v update-menus
command -v update-desktop-database
command -v xdg-desktop-menu
If any of those does not print a command path back, that's the reason why the script fails (silently).
I cannot find a package source repository of AnyDesk, otherwise we could fix that for them by changing the lines into this:
        ! command_exists update-menus || update-menus
        ! command_exists update-desktop-database || update-desktop-database
        ! command_exists xdg-desktop-menu || xdg-desktop-menu forceupdate
By this, the last returned check is "true", if the command does not exist, so the script only fails if running the actual command fails, which is intended.
valdragas
Post by valdragas »
Hello, I have carried out the steps you indicate and this is the result:
Without modifying the script
root@DietPi:~# /var/lib/dpkg/info/anydesk.postinst configure
Synchronizing state of anydesk.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable anydesk
root@DietPi:~# echo $?
1
root@DietPi:~# command -v update-menus
root@DietPi:~# command -v update-desktop-database
root@DietPi:~# command -v xdg-desktop-menu
After modifying the script with the three lines that you indicate changing $$ by ||
/var/lib/dpkg/info/anydesk.postinst: line 32: update-menus: command not found
Line 32 is:
32 command_exists update-menus || update-menus
valdragas
Post by valdragas »
Good,
any help with this?
Greetings
it might be good to have it reported to anydesk, if this is a bug within the apt package
@valdragas
Sorry for the late reply. Please add the leading "! " to the front of the three lines. You can copy paste the copy block:
valdragas
Post by valdragas »
It seems that after executing it with the MichaIng indications, the error no longer appears.
A greeting
Great. I'll report this the AnyDesk.
valdragas
Post by valdragas »
We know if it is better to open a new topic although it is related to the same thing, but today anydesk has stopped working again throwing this error:
root@DietPi:~# systemctl status anydesk
● anydesk.service - AnyDesk
   Loaded: loaded (/etc/systemd/system/anydesk.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2021-05-17 08:35:34 BST; 17min ago
  Process: 7920 ExecStart=/usr/bin/anydesk --service (code=exited, status=127)
 Main PID: 7920 (code=exited, status=127)
May 17 08:35:34 DietPi systemd[1]: Started AnyDesk.
May 17 08:35:34 DietPi anydesk[7920]: /usr/bin/anydesk: symbol lookup error: /lib/arm-linux-gnueabihf/libgdk_pixbuf-2.0.so.0: undefined symbol: g_direcp_equal
May 17 08:35:34 DietPi systemd[1]: anydesk.service: Main process exited, code=exited, status=127/n/a
May 17 08:35:34 DietPi systemd[1]: anydesk.service: Failed with result 'exit-code'.
root@DietPi:~# dpkg -l |grep libgdk
ii  libgdk-pixbuf2.0-0:armhf       2.38.1+dfsg-1                       armhf        GDK Pixbuf library
ii  libgdk-pixbuf2.0-common        2.38.1+dfsg-1                       all          GDK Pixbuf library - data files
What is the problem now?
probably as well something that might need to be reported to anydesk?
valdragas
Post by valdragas »
But it has been working correctly and after a reset of the PI this error has started to appear
