Dietpi fail to find eithernet connection at boot time Topic is solved
mail2rst
Re: Dietpi fail to find eithernet connection at boot time
Post by mail2rst »
amd64
these are the 3 packages to download for amd64
https://packages.debian.org/buster/amd6 ... n/download
https://packages.debian.org/buster/amd6 ... 2/download
https://packages.debian.org/buster/amd6 ... t/download
download them on an USB stick and mount the stick on your DietPi system. Go into the mounted directory and install the packages using dpkg -i *.deb
I hope it is working this way and no other dependency are missing.
mail2rst
Post by mail2rst »
during installation error come like this image https://pasteboard.co/JZumKhH.jpg
as unfortunately feared, you are missing some dependency.
Basically you would need to go package by package to the them all together :roll:
If you start with iproute2, you would need as well libcap2-bin
mail2rst
Post by mail2rst »
please send me the link, i will download it & put in same folder with same procedure
let's do it step by step and create 3 folder. This way we can avoid conflicts between the 3 packages
first one should contain iproute2 + libcap2-bin
mail2rst
Post by mail2rst »
out of four given packages three installed properly one again got error "isc-dhcp-client_4"
https://pasteboard.co/JZuyaBQ.jpg
mail2rst
Post by mail2rst »
Thanks @Joulinar with your guidance, i am able to install those packages & network is again up again, thanks you are always so helpful
ok good it's working again. I guess it was better this way than reinstall whole system. And don't forget to create a backup now ;)
