Static IP makes network unusable. Topic is solved
Re: Static IP makes network unusable.
traceroute is not installed by default. Therefore command is not working.
ifconfig depreciated and was replaced by ip command long time ago
maya95
Post by maya95 »
OK. Traceroute installed itself while waiting in ssh session. Traced to 8.8.8.8 fine.
root@DietPi:~# ip a
    inet6 ::1/128 scope host
    link/ether 00:0c:29:f4:ac:2e brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.103/24 brd 192.168.0.255 scope global dynamic eth0
       valid_lft 5892sec preferred_lft 5892sec
    inet6 fe80::20c:29ff:fef4:ac2e/64 scope link
Do you still have an issue?
trendy
Post by trendy »
Is this the DHCP scenario?
Can you repeat the ip neigh show ?
Is there any chance that you are running some kind of dhcp snooping or port-security?
maya95
Post by maya95 »
Joulinar wrote: Tue Apr 20, 2021 2:50 pm Do you still have an issue?
Yes.
Virtual Machine (x86_64) | IP: 192.168.0.5
┌──────────────────────────────┤ DietPi-Config ├───────────────────────────────┐
│ Please select an option to change:                                           │
│                          ●─ Adapter Options ──────────────●                  │
│                 Ethernet : Available | [On] | Connected                      │
│                 WiFi     : Not Found | [Off] | Disconnected                  │
│                          ●─ Additional Options ───────────●                  │
│                 IPv6     : [Off]                                             │
│                 Proxy    : [Off]                                             │
│                 Test     : [Failure] | Offline                               │
│                     <Ok>                         <Back>                      │
maya95
Post by maya95 »
trendy wrote: Tue Apr 20, 2021 2:51 pm Is this the DHCP scenario?
1. static / DNS set to 1.1.1.1 and 1.0.0.1
2.
192.168.0.1 dev eth0 lladdr b8:a3:86:fb:54:f4 REACHABLE
192.168.0.22 dev eth0 lladdr 00:60:6e:01:11:3a STALE
192.168.0.21 dev eth0 lladdr 64:00:6a:59:65:16 REACHABLE
3. no
maya95
Post by maya95 »
Noticed that when I reboot the VM, I got these messages and it counted to 60/60
can you do following and share the output
ping -4 -c 1 one.one.one.one
ping -4 -c 1 1.1.1.1
ping -4 -c 1 dns9.quad9.net
ping -4 -c 9.9.9.9
maya95
Post by maya95 »
root@DietPi:~# ping -4 -c 1 one.one.one.one
PING one.one.one.one (1.0.0.1) 56(84) bytes of data.
64 bytes from one.one.one.one (1.0.0.1): icmp_seq=1 ttl=60 time=10.3 ms
--- one.one.one.one ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 10.333/10.333/10.333/0.000 ms
root@DietPi:~# ping -4 -c 1 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=60 time=51.7 ms
--- 1.1.1.1 ping statistics ---
rtt min/avg/max/mdev = 51.693/51.693/51.693/0.000 ms
root@DietPi:~# ping -4 -c 1 dns9.quad9.net
PING dns9.quad9.net (149.112.112.9) 56(84) bytes of data.
64 bytes from dns9.quad9.net (149.112.112.9): icmp_seq=1 ttl=56 time=42.6 ms
--- dns9.quad9.net ping statistics ---
rtt min/avg/max/mdev = 42.643/42.643/42.643/0.000 ms
root@DietPi:~# ping -4 -c 9.9.9.9
Usage: ping [-aAbBdDfhLnOqrRUvV64] [-c count] [-i interval] [-I interface]
            [-m mark] [-M pmtudisc_option] [-l preload] [-p pattern] [-Q tos]
            [-s packetsize] [-S sndbuf] [-t ttl] [-T timestamp_option]
            [-w deadline] [-W timeout] [hop1 ...] destination
Usage: ping -6 [-aAbBdDfhLnOqrRUvV] [-c count] [-i interval] [-I interface]
             [-l preload] [-m mark] [-M pmtudisc_option]
             [-N nodeinfo_option] [-p pattern] [-Q tclass] [-s packetsize]
             [-S sndbuf] [-t ttl] [-T timestamp_option] [-w deadline]
             [-W timeout] destination
maya95
Post by maya95 »
OK. Last command should be
ping -4 -c 1 9.9.9.9
I's all good. But in Dietpi-Config network test https://dietpi.com , https://google.com http://apple.com always fail.
PING 9.9.9.9 (9.9.9.9) 56(84) bytes of data.
64 bytes from 9.9.9.9: icmp_seq=1 ttl=56 time=40.0 ms
--- 9.9.9.9 ping statistics ---
rtt min/avg/max/mdev = 39.997/39.997/39.997/0.000 ms
