Clean install errors Topic is solved
Re: Clean install errors
I guess @MichaIng could explain it better than I but the RPi4 is limited on the amount of power it can provide via USB. We had a couple of repots in the past on issues caused by this. Usually we recommend to use external power supply for external disks
DutchFlash
Post by DutchFlash »
Thanks, i will use the next time a external power supply for the ssd's.
