OrangePi Zero support
aliosa27
Re: OrangePi Zero support
Post by aliosa27 »
The internal wifi works fine. on boot however it fails, after the system has booted up it works fine. I added a line to re.local to ifup it, and in etc/network/interfaces I added a pre-up line to insmod the module.
Sciamano
Post by Sciamano »
That seems great! As soon as I get my OPi Zero I will try your image. Thanks!
andymetallic
Post by andymetallic »
As a fairly new user DietPI and Linux in general, is there any way to get the Orange Pi Zero to run a desktop? I want to run it remotely using xrdp and/or tightvncserver. Is this possible with the current build?
Fourdee
Post by Fourdee »
andymetallic wrote:Hi,
Yep, just tried tightvncserver on OPi Zero, works a charm :)
Just remember its on screen 1, so IP:1 http://dietpi.com/phpbb/viewtopic.php?f ... rt=30#p408
TV31
Post by TV31 »
Hi
I am new to DietPi but old enough for SBC with some humble knowledge on Linux.
I am install diet pi say V139 on OPi Zero and config for Wifi connect on dietpi.txt.
It worked perfectly and I have ssh connect.
However, after upgrade to V140, It can't connect to network any more.
I intended to config Opi zero as network player to my USB DAC.
Any hint for this? I have try several times re-flash but getting stuck after upgrade and reboot to V140.
Thank you.
Fourdee
Post by Fourdee »
TV31 wrote:However, after upgrade to V140, It can't connect to network any more.
Strange, theres nothing in the v140 patch that targets OPi Zero or would effect WiFi.
Please try this service to resolve WiFi:
There is a known issue with WiFi modules failing to load during boot, on some boards. This may resolve the issue.
https://github.com/Fourdee/DietPi/issue ... -266006050
Failing that, please paste results of following commands, so we can check for any errors:
dmesg | grep xradio
dmesg | grep wlan0
TV31
Post by TV31 »
dmesg | grep xradio
dmesg | grep wlan0
I get Wifi connected after resolve Wifi. Thanks.
Another issue
Update & upgrade APT
Please wait...
Ign http://ftp.cn.debian.org jessie InRelease
Get:1 http://ftp.cn.debian.org jessie-updates InRelease [145 kB]
Hit http://security.debian.org jessie/updates InRelease
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
[Info] Running apt simulation to check for errors, please wait...
[Failed] Apt simulation | An issue has occured
[Failed] The apt cache may be corrupt, apt mirror offline, or you have held broken pacakages. DietPi-Software will now exit.
[Info] Please try:
[Info] - Fixing apt package errors with 'apt-get install -f'
[Info] - Change apt mirror: 'dietpi-config' > 'Networking: NAS/MISC' > 'Apt Mirror'
[Info] - Clear and refresh apt 'apt-get update'
[Info] - If problems persist, please create a Git ticket so DietPi can investigate the issue:
- https://github.com/Fourdee/DietPi/issues
Fourdee
Post by Fourdee »
TV31 wrote:Another issue
Yep, this is fixed for v141, its as if Debian has forced https redirect on their security repo overnight, but you can manually patch with:
- ARMv7
- https://github.com/Fourdee/DietPi/issue ... -269344844
TV31
Post by TV31 »
- ARMv7
Apply fix manually but still error
dpkg: dependency problems prevent configuration of apt-transport-https:
apt-transport-https depends on libapt-pkg4.12 (>= 1.0.9.8.4); however:
Version of libapt-pkg4.12:armhf on system is 1.0.9.8.3.
k-plan
Post by k-plan »
TV31 wrote:Apply fix manually but still error
can you please test this:
https://github.com/Fourdee/DietPi/issue ... -269472619
