mosquitto Error: Address already in use Topic is solved
Re: mosquitto Error: Address already in use
Well DietPi doesn't do anything on that update. It is an apt package directly installed from mosquitto repository using apt package manager. Probably this is behavior of mosquitto v2 as security requirements changed. But better to check with mosquitto directly
novitibo
Post by novitibo »
after mosquitto upgrade:
DietPi-Services
Mode: status mosquitto
[ INFO ] DietPi-Services | mosquitto inactive (dead)
with "dietpi-software reinstall 123" no luck also
pls share following
systemctl status mosquitto.service
cat /var/log/mosquitto/mosquitto.log
novitibo
Post by novitibo »
root@DietPi:/etc/mosquitto# systemctl status mosquitto.service
● mosquitto.service - Mosquitto MQTT Broker daemon
   Loaded: loaded (/etc/systemd/system/mosquitto.service; disabled; vendor preset: enabled)
   Active: inactive (dead)
Mar 23 14:02:42 DietPi systemd[1]: /etc/systemd/system/mosquitto.service:11: PIDFile= referen
ces path below legacy directory /var/run/, updating /var/run/mosquitto.pid → /run/mosquitto.pid; please update the un
it file accordingly.
Mar 23 14:02:57 DietPi systemd[1]: /etc/systemd/system/mosquitto.service:11: PIDFile= referen
Mar 23 14:02:57 DietPi systemd[1]: Started Mosquitto MQTT Broker daemon.
Mar 23 14:02:57 DietPi systemd[1]: mosquitto.service: Succeeded.
Mar 23 14:03:38 DietPi systemd[1]: /etc/systemd/system/mosquitto.service:11: PIDFile= referen
Mar 23 14:06:03 DietPi systemd[1]: /etc/systemd/system/mosquitto.service:11: PIDFile= referen
Mar 23 14:06:14 DietPi systemd[1]: /etc/systemd/system/mosquitto.service:11: PIDFile= referen
Mar 23 14:06:14 DietPi systemd[1]: Started Mosquitto MQTT Broker daemon.
Mar 23 14:06:14 DietPi systemd[1]: mosquitto.service: Succeeded.
Mar 23 14:07:19 DietPi systemd[1]: /etc/systemd/system/mosquitto.service:11: PIDFile= referen
log file is empty :?
can you share you config file pls
cat /etc/mosquitto/mosquitto.conf
novitibo
Post by novitibo »
Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
allow_anonymous false
password_file /etc/mosquitto/users.passwd
listener 1883
pls can you able the line with pointing to the mosquitto.pid file. Should looks like this
#pid_file /var/run/mosquitto.pid
pid_file /run/mosquitto/mosquitto.pid
pls check if directory /run/mosquitto/ exist
and restart mosquitto afterwards.
novitibo
Post by novitibo »
that folder was not there, I created it, rebooted the system and...
[ INFO ] DietPi-Services | mosquitto inactive (dead) :x :cry:
That's a tmpfs (RAMdisk), any files there are to live only for the lifetime the service runs. When the default configuration uses /run/mosquitto.pid that's fine as no directory needs to be created. But the daemon does not have permissions to create a file there, which is probably the reason for the issue. Is the PID file really created by default there or did you add/set that setting manually? It would be basically a bug with their systemd unit as unprivileged users are never intended to create files there, so the systemd unit must handle this with root privileges. The PID file is actually not required with systemd, so the cleanest solution wound be to unset that setting.
