npm and node_index.js high CPU load
novitibo
Re: npm and node_index.js high CPU load
Post by novitibo »
Joulinar wrote: Tue Jan 26, 2021 10:59 am Did you tried to installgit via dietpi-software?
yeah, but then after git clone... git: command not found :x
do we have to use git some other way?
there is nothing special on git
you could check if git is existing by simply running git on command line. Usually it should give some help information
