PiVPN with Wireguard and PiHole not working correctly Topic is solved
Re: PiVPN with Wireguard and PiHole not working correctly
ok I was asking because Docker block routing functionality by default https://docs.docker.com/network/iptable ... n-a-router
But if it is not installed, it should not have an impact
@trendy
It's about Wireguard server installed on the DietPi device where it is not possible to reach systems behind DietPi/Wireguard server. Something wrong on routing from wg0 interface into local network.
nilsacht
Post by nilsacht »
trendy wrote: Tue Jan 19, 2021 10:18 am Is it possible to get the following before and after you connect to the VPN?
ip -4 addr; ip -4 ro li table all; ip -4 ru; iptables-save -c; netstat -lnp
and point out which service is not running after the vpn is up.
Is it possible to save the output in a file? That's a lot of output i get with this commands.
trendy
Post by trendy »
Joulinar wrote: Tue Jan 19, 2021 10:19 am @trendy
I thought as much.
nilsacht wrote: Tue Jan 19, 2021 10:25 am Is it possible to save the output in a file? That's a lot of output i get with this commands.
Maybe you can use pastebin?
nilsacht
Post by nilsacht »
The output befor vpn connection:
http://sprunge.us/qAtrEZ
The output after vpn connection:
http://sprunge.us/dWRCKL
trendy
Post by trendy »
Only the last command is pasted in both files.
nilsacht
Post by nilsacht »
Ok i take a look and post all soon
as well you could execute them one by one and post the output in separat files to get more visibility
ip -4 addr
ip -4 ru
iptables-save -c
netstat -lnp
trendy
Post by trendy »
Try it like this:
sudo ip -4 addr > file.txt; sudo ip -4 ro li table all >> file.txt; sudo ip -4 ru >> file.txt; sudo iptables-save -c >> file.txt; sudo ss -tulnp >> file.txt
Sibbefufzich
Post by Sibbefufzich »
Hey guys,
Ok, first up: My problem is IPv6 only, so I kinda feel like hijacking this Thread. If you think I should open a new one, please let me know.
I also executed the suggested commands (although not IPv6 specific I guess) and this is th output before connecting the client to the server:
ip -4 addr:
    inet 192.168.0.3/24 brd 192.168.0.255 scope global eth0
9: wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
    inet 192.168.0.3/24 scope global wg0
ip -4 ro li table all:
default via 192.168.0.1 dev eth0 onlink
192.168.0.0/24 dev eth0 proto kernel scope link src 192.168.0.3
192.168.0.0/24 dev wg0 proto kernel scope link src 192.168.0.3
broadcast 127.0.0.0 dev lo table local proto kernel scope link src 127.0.0.1
broadcast 192.168.0.0 dev eth0 table local proto kernel scope link src 192.168.0.3
broadcast 192.168.0.0 dev wg0 table local proto kernel scope link src 192.168.0.3
local 192.168.0.3 dev eth0 table local proto kernel scope host src 192.168.0.3
local 192.168.0.3 dev wg0 table local proto kernel scope host src 192.168.0.3
broadcast 192.168.0.255 dev eth0 table local proto kernel scope link src 192.168.0.3
broadcast 192.168.0.255 dev wg0 table local proto kernel scope link src 192.168.0.3
ip -4 ru:
0:	from all lookup local
32766:	from all lookup main
32767:	from all lookup default
iptables-save -c:
<no output>
And now, weird:
netstat -lnp:
-bash: netstat: command not found
After connecting to the wireguard server, the only output that changed was the missing
in the ip -4 ro li table all output.
trendy
Post by trendy »
If your problem is with IPv6 only, then these commands will not give any useful output.
Better start a new thread and we can discuss it there.
I have updated the commands with sudo (in case you run them as dietpi user) and changed the obsolete netstat with ss (old habits die hard).
