@MichaIng
Another quest that stepped into my mind. Looks like Ampache has quite some specific web server config files. https://github.com/ampache/ampache/wiki ... figuration
Should we try to adapt on our side?
Nginx and Ampache
Re: Nginx and Ampache
Jep makes sense. The .htaccess files are installed correctly, but security headers make sense and for other webservers additionally the access permissions.
@Joulinar
I am able to run Ampache but not able to configure it for subsonic backend and upnp backend. I have been searching all over the internet for Lighttpd or Nginx but no success. I have no knowledge of webservers. Ampache wiki page provides help for configuring different servers but I am clue less on which file and their location.
Could you guys autoconfigure servers based on ampache wiki while installing Ampache from dietpi-software.
Thanks in advance.
I want to use it along with pihole.BUT using this configuration will manipulate Nginx away from DietPi standard and Nginx will be useable for Ampache only
Thanks in advance.
well, something that we will look into. But nothing we can promise. As always, to many open items / request than time to implement all
