RaspberryPi4 RPi4 Upgrading from existing SD card setup to boot from SSD
RollingDutch
Contact:
Re: RaspberryPi4 RPi4 Upgrading from existing SD card setup to boot from SSD
Post by RollingDutch »
Okay,
I did the steps provided in the first post. Made an img-file from the sd-card, flashed that to the SSD drive. Then followed the instructions from https://www.instructables.com/Booting-R ... USB-Drive/
In short:
sudo apt update && sudo apt upgrade && sudo reboot
echo program_usb_boot_mode=1 | sudo tee -a /boot/config.txt
sudo reboot
vcgencmd otp_dump | grep 17:
reboot
The OTP seems to have been programmed correctly
But....
When restarting the PI nothing happend :(
I'm afraid that something didn't quite work in the original instructions on the first post
Do you have a pen steck? Would it be possible to flash a fresh copy of DietPi on that stick and try to boot from it? Just to check of USB boot is working.
RollingDutch
Contact:
It's not a stick, it's a 'normal' SSD drive.
Will try to flash a new Dietpi install tomorrow.
I guess we misunderstood. For testing, you could try using a pen stick instead of your SSD to see how it behave.
RollingDutch
Contact:
Tried with USB stick I had lying around. Didn't want to startup either. So I flashed some other SD-card with the img I created earlier in the hope that will work again., but that also fails now.
Btw. I can see that the PI is up (at least in the DHCP table of my router it shows up.
does it boot with the original SD card? How does it behave if you flash a complete new/fresh image to SD/ pen stick?
RollingDutch
Contact:
Just flashed the newest Bullseye to a stick, and it seems that one is booting. At least I could login and start the dietpi install. So, waiting to see what happens next.
RollingDutch
Contact:
Seems to be working so far.
ok means USB boot is working well. Probably there is an issue with the *.img file you create because it was not working as well on another SD card if I understood correctly? How did you created the image?
RollingDutch
Contact:
I cloned the card with Win32 diskimager.
