RaspberryPi4 RPi4 Upgrading from existing SD card setup to boot from SSD
dobbyzioso
Re: RaspberryPi4 RPi4 Upgrading from existing SD card setup to boot from SSD
Post by dobbyzioso »
So should I use this device ?
Because there was an hint with my device ID
Bus 001 Device 003: ID 152d:1561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS561U two ports SATA 6Gb/s bridge
Edit:
Well this works. Thank you very much. Forgot the :u behind my ID
maybe you like to have a look to this one first. viewtopic.php?f=9&t=8349
There was a report about challenges on JMicron USB to SATA adapter
billouetaudrey
Post by billouetaudrey »
JMICRON not working on USB3 on my device
I change to Innostor Technology Corporation and working fine now
https://jamesachambers.com/raspberry-pi ... sh-drives/
so again the JMICRON controller right?
billouetaudrey
Joulinar wrote: Tue Jan 19, 2021 3:49 pm so again the JMICRON controller right?
My Jmicron work only on USB2 port ( approx 30mb/sec )
Approx 200MB/Sec in write and read with SSD on USB3
ok good at least it's working for you using a different one. So good to keep in mind these JMicron adapter
billouetaudrey
Joulinar wrote: Tue Jan 19, 2021 10:53 pm ok good at least it's working for you using a different one. So good to keep in mind these JMicron adapter
Yes I do that, hope I will not dead because I take from an other old hard disk usb lol
So if death, I need to find an other work too on us 3
Sorry for my bad english, I'm french...
oengus
Post by oengus »
Just wanted to chime in, for future searchers, I just this the steps in the first message of this post to transfer from an SD to a 128gb USB3.1 flawlessly. I did update the EEPROM, but otherwise, I had no trouble whatsoever.
I used Apple Pi Baker since I'm on a mac for imaging the SD card.
