wireguard successfully installed, but where to go from here? Topic is solved
naddel81
Re: wireguard successfully installed, but where to go from here?
Post by naddel81 »
WORKS NOW! UDP was the way to make it work.
thanks for helping me out!
Legend
yes you need to forward UDP and not TCP
naddel81
Post by naddel81 »
about 55 mbit/s is maximum on my pi 2b, where it was 20 mbit/s on the pi zero throughput.
is that OK?
