One RPI gets IPv6 but the other doesn't!
Ferrari Steve
Post by Ferrari Steve »
I've got two RPI 3+ running DietPi on Buster. The only difference between the RPIs should be their hostname and IP addresses. But the other major difference is that RPI #1 doesn't get issued an IPv6 and RPI #2 does. I've tried comparing as many config files as I can find and they look the same.
I'm pulling what's left of my hair out. IPv6 is enabled for both in dietpi-config. Both /etc/network/interfaces files look like this:
# Drop-in configs
source interfaces.d/*
# Loopback
auto lo
iface lo inet loopback
# Ethernet
allow-hotplug eth0
iface eth0 inet dhcp
address 192.168.1.106
netmask 255.255.255.0
gateway 192.168.1.1
#dns-nameservers 127.0.0.1
# WiFi
#allow-hotplug wlan0
iface wlan0 inet dhcp
address 0.0.0.0
netmask 0.0.0.0
gateway 0.0.0.0
#dns-nameservers 0.0.0.0
wireless-power off
With the only difference being the address line under #Ethernet (which shouldn't really matter with DHCP anyway).
I've tried adding "iface eth0 inet6 dhcp" to RPI#1, but that doesn't do anything -- and RPI#2 doesn't seem to need that line to get an IPv6 address.
RPI#1 does get a local IPv6 address (starting with fe80).
From RPI#2 I can ping RPI#1's local IPv6:
RPI2# ping6 fe80::ba27:ebff:feb4:ffd4
PING fe80::ba27:ebff:feb4:ffd4(fe80::ba27:ebff:feb4:ffd4) 56 data bytes
64 bytes from fe80::ba27:ebff:feb4:ffd4%eth0: icmp_seq=1 ttl=64 time=0.711 ms
64 bytes from fe80::ba27:ebff:feb4:ffd4%eth0: icmp_seq=2 ttl=64 time=0.492 ms
64 bytes from fe80::ba27:ebff:feb4:ffd4%eth0: icmp_seq=3 ttl=64 time=0.655 ms
^C
--- fe80::ba27:ebff:feb4:ffd4 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 71ms
rtt min/avg/max/mdev = 0.492/0.619/0.711/0.095 ms
However, RPI#1 cannot ping either RPI#2's IPv6 addresses. One address does this:
RPI1# ping6 2601:601:c97f:d407:ba27:ebff:fe4a:a62c
connect: Network is unreachable
the other does:
RPI1# ping6 fe80::ba27:ebff:fe4a:a62c
PING fe80::ba27:ebff:fe4a:a62c(fe80::ba27:ebff:fe4a:a62c) 56 data bytes
and just hangs.
Any ideas?
Re: One RPI gets IPv6 but the other doesn't!
many thanks for your report. Pls can you try running the following
/boot/dietpi/func/dietpi-set_hardware enableipv6 enable
To verify assigned IP address you can use ip a
trendy
Post by trendy »
Have you enabled any firewall on the problematic Pi by any chance?
ip6tables-save -c
Ferrari Steve
Joulinar wrote: Sun Jun 21, 2020 9:02 pm
RPI1# /boot/dietpi/func/dietpi-set_hardware enableipv6 enable
 DietPi-Set_hardware
 Mode: enableipv6 (enable)
[  OK  ] DietPi-Set_hardware | Desired setting in /etc/hosts was already set: ::1 localhost ip6-localhost ip6-loopback
[  OK  ] DietPi-Set_hardware | Desired setting in /etc/hosts was already set: ff02::1 ip6-allnodes
[  OK  ] DietPi-Set_hardware | Desired setting in /etc/hosts was already set: ff02::2 ip6-allrouters
[  OK  ] DietPi-Set_hardware | Desired setting in /boot/dietpi.txt was already set: CONFIG_ENABLE_IPV6=1
[  OK  ] enableipv6 enable | Completed
Ferrari Steve
trendy wrote: Sun Jun 21, 2020 9:19 pm Have you enabled any firewall on the problematic Pi by any chance?
Nope. :(
Running "ip6tables-save -c" output is empty.
What does ip a gives back?
Ferrari Steve
RPI1# ip a
    inet6 ::1/128 scope host
    link/ether b8:xxxxxxx brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.105/24 brd 192.168.1.255 scope global dynamic eth0
       valid_lft 65435sec preferred_lft 65435sec
    inet6 fe80::ba27:ebff:feb4:ffd4/64 scope link
3: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 100
    link/none
    inet 10.8.0.1 peer 10.8.0.2/32 scope global tun0
    inet6 fe80::fa66:ff1d:67b1:2bc0/64 scope link stable-privacy
4: wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
    link/none
    inet 10.6.0.1/24 scope global wg0
looks like there is an IPv6 address assigned on eth0
are you able to ping this address from your system themselves ?
Ferrari Steve
That's a self-assigned link-local address only (starts with fe80). It should also have a global one (which it receives from the router) starting with 2601, like the rest of the devices on this network segment -- including the other RPI which SHOULD be a clone of the other that works.
RPI2 can ping RPI1's link-local IPv6:
64 bytes from fe80::ba27:ebff:feb4:ffd4%eth0: icmp_seq=1 ttl=64 time=0.703 ms
64 bytes from fe80::ba27:ebff:feb4:ffd4%eth0: icmp_seq=2 ttl=64 time=0.657 ms
But RPI1 cannot ping RPI1's link-local or global IPv6. It attempts to do on on link-local:
^C
--- fe80::ba27:ebff:fe4a:a62c ping statistics ---
6 packets transmitted, 0 received, 100% packet loss, time 211ms
but complains that there's no IPv6 network available at all if I try the global:
I know it might be nonsense but what happen if you swap SD card between the 2 devices. Is the "issue" moving as well?
