Kodi don't start Topic is solved
Re: Kodi don't start
Solved with: https://github.com/MichaIng/DietPi/commit/48ad84b
Changelog: https://github.com/MichaIng/DietPi/blob ... OG.txt#L10
I'm thinking to send a live patch as well :?.
Klola
Post by Klola »
All right, then it was not me :)
Recommendation? Kodi uninstall, wait for patch, Kodi reinstall?
The patch was about having the X server installed with Kodi on RPi 64-bit systems, which you already did, not about the addons repository.
For the letter, it's a dedicated package on Debian :):
apt install kodi-repository-kodi
Something we may want to add to our docs :?. I'm just not sure if that is required or whether the same package works with the Kodi for RPI 32-bit mages and the ones for Odroids.
@MichaIng
Should we install the repository package in addition to Kodi by default?
Klola
Post by Klola »
Thanks, the live patch was shown to me, likewise I was able to apt install kodi-repository-kodi the repository. Seems to good for me now :)
Joulinar wrote: Fri Sep 24, 2021 5:16 pm @MichaIng
Probably makes sense, at least for the Debian kodi package. I'll check weither it is needed for RPi, our own and Odroid Kodi as well.
I did a test installation using our image and the point was available
