just installed dietpi, can't login Topic is solved
TWHH
Re: just installed dietpi, can't login
Post by TWHH »
I'm having a similar problem. Am a total noob. Only ever pointed, clicked, dragged and dropped before :D :D
Bought a RPi 'kit' that came with SD card with 'NOOBS' installed on it. Have used balenaEtcher to flash the drive with DietPi. Tried deleting the SD card in Disk Utility (I'm a Mac user) and re-flashing... same issue. Being told my password is incorrect when trying to SSH into the Pi.
Can anyone walk me through how to properly prepare the SD card before reflashing the DietPi image onto said SD card?
Many thanks
if you use the default system, just flashed the SD card without configuration, the default password is dietpi
TWHH
Post by TWHH »
on further searching a found a thread that had the Terminal command as ssh root@IPaddress. I had been doing ssh pi@IPaddress
I'm now in... after about an hour of faffing!
user pi did not exit on DietPi ;)
I recommend to have a look to our online docs https://dietpi.com/docs/
There is quite a good section about first start
TWHH
Post by TWHH »
I did do a lot of reading... that bit just slipped through the net!
All good now. Pi is busy loading up desired software.
I do like a project :)
