DietPi-Login DNS Resolver Not Working Topic is solved
gamingunfinished
Re: DietPi-Login DNS Resolver Not Working
Post by gamingunfinished »
root@DietPi:~# cat /DietPi/dietpi.txt |grep CONFIG_ENABLE_IPV6
CONFIG_ENABLE_IPV6=0
root@DietPi:~# ip a
inet6 ::1/128 scope host
link/ether b8:27:eb:62:d5:fd brd ff:ff:ff:ff:ff:ff
inet 192.168.1.69/24 brd 192.168.1.255 scope global eth0
inet6 2606:a000:1408:8269:ba27:ebff:fe62:d5fd/64 scope global dynamic mngtmpaddr
valid_lft 604509sec preferred_lft 604509sec
inet6 fe80::ba27:ebff:fe62:d5fd/64 scope link
Legend
did you reboot your system after you disabled IPv6? If not, pls do. Because you still have an IPv6 address assigned
gamingunfinished
yes, I did. Should I disable ipv6 on my router?
Legend
you can try, It's strange that you have IPv6 addresses on your eth0 adaptor
gamingunfinished
That worked. I'd like to keep ipv6 on though, is there another way to turn it off for the Pi?
Legend
you can go to
  1. dietpi-config tool
  2. 7 : Network Options: Adapters
  3. IPv6 : [Off]
this should deactivate IPv6 on your SBC. But this is the same setting as CONFIG_ENABLE_IPV6=0 within dietpi.txt file. If IPv6 was disabled, the command ip a should return an IPv4 address only.
gamingunfinished
Thanks for your help
Legend
yw 8)
iDopamin3
Post by iDopamin3 »
I made an account just to say thank you, the IPv6 was holding me back!
dvd741
Post by dvd741 »
I have the same issue. Sort of... Sometimes.
Ping -c 1 dns9.quad.net
Sometimes gives 100% packet loss.
Sometimes gives 1 received.
Iperf3 to a host on my network runs fine (speeds close to 1Gbps)
Do you have any idea what might be the cause? (Rock Pi 4B 1.72 on Dietpi with kernel 5.10.63)
P.s. IPV6 is disabled and ip a shows no ipv6 ip
Could it be a dns problem? And how should I investigate the cause? :-/
