[Resolved] XU4 fails to power on
rlamans
Re: V132 XU4
Post by rlamans »
I noticed the problem way back at v122 (?) and stopped using Dietpi because of it. I have used my cloudshell with OMV, Ubuntu 16.04, and android with no power off problems. If the problem was with the power source you would think the issue would show up with other distros - but it seems to only be a problem with Dietpi. I am back to Dietpi because I love it, but it is not usable without a fix to the power down problem.
I have a cloushell with a 320G HD - the HD was used with the other distros also ...
I tested the power off issue with a clean Dietpi - immediately after file system expansion and no other software installed and experienced the same problem. Hope this helps.
Fourdee
Re: V132 XU4
Post by Fourdee »
rlamans wrote:I noticed the problem way back at v122 (?) and stopped using Dietpi because of it. I have used my cloudshell with OMV, Ubuntu 16.04, and android with no power off problems. If the problem was with the power source you would think the issue would show up with other distros - but it seems to only be a problem with Dietpi. I am back to Dietpi because I love it, but it is not usable without a fix to the power down problem.
So just to clarify, the issues you and other users are experiencing are:
1. When you run the command poweroff, the XU4 will not power back on again? Either using the power on button, or, physically reinserting the PSU?
2. When you physically remove the PSU without shutting down, the XU4 fails to power on again?
Can all users who have experienced these issue please list:
- The board revision number/dates on their XU3/4.
- Power supply used (eg 5v/6a)
- SD/EMMC card used and size.
- If you have time, please try installing the following image http://oph.mdrjr.net/meveric/images/Jes ... XU3.img.xz, (username = root, pw = odroid) run apt-get update and apt-get dist-upgrade -y && reboot, then please try to replicate the power on issue you are experiencing (eg: Pull power plug and put back in again, or poweroff)
Also created a Git ticket so we can investigate this: https://github.com/Fourdee/DietPi/issues/558
luzifia
Re: XU4 fails to power on
Post by luzifia »
Hi There
As far as i know the last working Image was V130.
Power Supply (original one): 5v/4a
XU4 Rev 0.1 20151201
1st Try eMMC: 64GB
2nd Try MircoSD: 16GB
StartImage: DietPi_v127_OdroidXU4-armv7-(Jessie).img
huch - The Installation takes a while.
Tried on MicroSD 16GB
i've done this and the xu4 reboots. I only can read 6 Lines on the Display the rest seems to be black text-foreground ... but the xu4 react on entered commands (reboot, poweroff).
Luzi
Fourdee
Post by Fourdee »
Hi All,
I've recreated the XU4 image for DietPi: https://github.com/Fourdee/DietPi/issue ... -254057278
Could all users who are experiencing power on failures after shutdown, please download the image below and re-test. Thanks.
Image link: https://dietpi.com/downloads/images/Die ... -Buster.7z
rlamans
Post by rlamans »
In my case I used the desktop "shutdown" and did not remove the power plug. I also tried to remove the power plug after - but it did not boot.
Also, I used the "poweroff" and "shutdown" commands in terminal with the same results. At no time did I just pull the plug because that is really bad for the XU4 board and SD card.
PS - it appears the link in the post to try a new image is inactive ...
rlamans
Post by rlamans »
I tried the RC2 link above after performing an update, upgrade, and reboot ... "poweroff", "shutdown now", and restart via the push button worked as expected.
Fourdee
Post by Fourdee »
rlamans wrote:In my case I used the desktop "shutdown" and did not remove the power plug. I also tried to remove the power plug after - but it did not boot.
We moved the image to live download, new link is https://dietpi.com/downloads/images/Die ... -Buster.7z, apologies for that.
If you could run the same tests on the image above, i'd be extremely greatful. One of our other users has confirmed the issue is now resolved with that image, but, we'd like to get a few more results before closing this one.
rlamans
Post by rlamans »
Ok, but it will be a couple days ... have to pay the bills!
Fourdee
Post by Fourdee »
rlamans wrote:Ok, but it will be a couple days ... have to pay the bills!
No worries, know the feeling ;)
luzifia
Post by luzifia »
Hi
Fourdee wrote:Hi,
Yes it runs with the new Image- tried on MicroSD 16GB.
Fourdee, is there a way now to upgrade my running System V130 to V134 without new Installation?
Luzi
