dietpi-drive_manager possible bug Topic is solved
johnvick
Legend
Post by johnvick »
@MichaIng
I have just run dietpi-drive_manager and exited without doing anything and it removed a custom line in /etc/fstab I use to mount an ecryptfs folder. Repeated with same result.
Latest version 6.22.3 but looking through my backups it occurred earlier than this.
John
johnvick
Legend
Re: dietpi-drive_manager possible bug
Post by johnvick »
Just found you were aware of this
https://github.com/MichaIng/DietPi/issues/2078
I've had ecryptfs running for ages - do you need to remove the line from /etc/fstab? It means I have to manally restore it if I use dietpi-drive_manager.
John
Yeah indeed that is nasty. I will add this to v6.23 milestone (ah it is already).
Is there a way to check existing/active encryptfs mounts outside of fstab? As df does not indicate whether it's encryptfs or something else. blkid and lsblk do not show it because it's no block device.
Ah df -T shows it in the Type column, right?
johnvick
Legend
Post by johnvick »
@MichaIng
On v 6.24.1 on Z83 - used dietpi-drive_manager and it again removed the ecryptfs entry in /etc/fstab - which I note had been fixed in 6.23 changelog?
Yes df -T shows it.
John
@johnvick
Hmm how does the fstab entry for the encryptfs mount look like?
I assumed something like this:
/mnt/point /mnt/point ecryptfs defaults 0 0
This line should be caught by:
grep -E '^[[:blank:]]*[^#].*([[:blank:],]bind[[:blank:],]|[[:blank:]](encryptfs|vboxsf)[[:blank:]])' /etc/fstab
... damn found it: encryptfs vs ecryptfs ...
To fix:
sed -i 's/encryptfs/ecryptfs/g' /DietPi/dietpi/dietpi-drive_manager
Fixed for v6.25: https://github.com/MichaIng/DietPi/comm ... ae269936c6
Changelog: https://github.com/MichaIng/DietPi/comm ... 9bdb5af5f2
Always read it with an "n" :roll:, sometimes copy&paste makes sense...
johnvick
Legend
Post by johnvick »
@MichaIng
Thanks for fixing.
For reference my line is:
#Ecryptfs
/home/john/crypt /home/john/crypt ecryptfs defaults,noatime,nofail 0 0
Thanks, okay with the removed "n" this will be detected and preserved now.
