Locked
Fourdee
v144
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/dietpi_tools/#configuration
DietPi-Services
DietPi-Services allows to control the service states of all installed software, as well as tweak system wide nice/priority levels, CPU affinity and scheduler policies.
DietPi will automatically start and stop services as needed, e.g. during boot, shutdown, backups and software installations.
Stop services: dietpi-services stop
Start services: dietpi-services start
Service status: dietpi-services status
Include/Exclude services:
  • Option 1: Start dietpi-services and use the Add menu entry, respectively the Include/Exclude service submenu entry.
  • Option 2: Create/edit the following file: /boot/dietpi/.dietpi-services_include_exclude
    Add + entries for each additional service you wish to control. Add - entries for items you wish to exclude. Example:
    + service1
    - deluged
    - deluge-web
    + mightymoocow
    - lighttpd
Process tool tweaks:
  • Nice:
    As all active processes share the same CPU, DietPi-Process Tool allows you to control which processes are more or less important. By setting a higher priority level (nice), the software process will be given more of the CPU shared resources, essentially reducing any delay from other software processes.
  • Affinity:
    For systems with multiple cores, you can control which cores are available for each program.
  • Scheduler policies:
    For time critical programs (eg: audio processes / robotics), setting the scheduler to FIFO/RR will ensure maximum priority and "real-time" execution. Further information.
  • Example system:
    • Your server runs Pi-hole and a web server.
    • Pi-hole is the main use of this server, and, you want to reduce any possible delay from other programs.
    • So we set Pi-Hole to a higher priority level of nice -10.
    • Pi-hole will now be more responsive. Its users should not experience random delays when browsing the web.
Fourdee
v145
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/hardwa ... ynk-server
Blynk Server
Platform with iOs and Android apps to control Arduino, ESP8266, Raspberry Pi and similar microcontroller boards over the Internet.
Also installs:
  • Blynk JS Libary
Install notes:
  • DietPi installs Blynk (including user data and config file) to the following location:
    /mnt/dietpi_userdata/blynk
  • Log files can be found in: /var/log/blynk
  • We created a systemd service for Blynk, DietPi will automatically start this:
    systemctl status blynkserver
  • DietPi will also install Blynk JS Libary, along with this installation. Please skip this section when you reach the Blynk user guide.
Access web admin interface: Server configuration:
  • NB: The config "file" changes in the web UI do not have an effect yet: https://github.com/blynkkk/blynk-server/issues/1318
  • To change settings you need to edit /mnt/dietpi_userdata/blynk/server.properties
    and restart the Blynk server: systemctl restart blynkserver
Official documentation: Install Blynk App (Android): Getting started with Blynk App:
  • To log into your own server, press Log In, then the three dots at the bottom and switch the slider to CUSTOM. There you can enter your own Blynk servers IP/domain and use the above login credentials.
  • You can then skip creating an external Blynk account and instead go on and create a new project directly: https://docs.blynk.cc/#getting-started- ... ew-project
Run test script:
  • Once you create a project in the iOS/Android App, replace the following with your auth code, then run the command:
    blynk-client Replace_With_Your_Auth_Code
Update to the latest version:
  • dietpi-software reinstall 131
Fourdee
v147
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittorrent/#aria2
Aria2
Download manager, with a slick web UI interface. Also supports BitTorrent downloads.
Also installs:
Access web interface:
  • url = http://192.168.0.100/aria2/docs
  • rpc secret password = dietpi
    This needs to be entered in the following location, in the web interface:
    • Settings
    • Connection Settings
    • Enter the rpc secret password into the Enter the secret token (optional): box, then save changes
Access downloads: Make changes to Aria2 settings permanently:
Please note, the aria2-webui does not support saving settings after session shutdown, this is a known limitation with the software, please use the aria2.conf to make changes:
  • Stop services with dietpi-services stop
  • Edit the following configuration file /mnt/dietpi_userdata/aria2/aria2.conf, making your required changes.
  • Start services with dietpi-services start
  • Full list of aria2.conf settings: https://aria2.github.io/manual/en/html/aria2c.html
Recommended: Protect your privacy with a VPN:
Although we enable forced encryption on all our BitTorrent clients, if you wish to ensure complete privacy and peice of mind for all your downloaded content, using a VPN is critical.
Fourdee
v147
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/distri ... ects/#yacy
YaCy
Decentralized open source search engine. Essentially, "peer 2 peer" Google search engine, not controlled by Google ;)
URL = http://192.168.0.100:8090
Admin Interface Login:
Set password with:
/etc/yacy/bin/passwd.sh mypassword
Login details are then:
  • Username = admin
  • Password = mypassword
Reduce CPU usage:
YaCy is extremely CPU intensive, coupled with constant background processing, we highly recommend using dietpi-services to reduce process priority.
  • Recommended setting: Nice = 19
Fourdee
v148
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/#icecast
IceCast
Shoutcast streaming server, includes DarkIce for audio input (eg: mic).
Install notes:
  • DietPi will attempt to detect mic input during installation, and apply to DarkIce. If a mic was not available, or you experience issue, check available mics with:
    arecord -l
    • Then edit the device entry in /etc/darkice.cfg, or
    • Simple copy and paste:
      sed -i "/^device[[:space:]]/c\device = hw:$(arecord -l | grep -m1 'card' | awk '{print $2}' | sed 's/://'),0" /etc/darkice.cfg
    • Restart services
      dietpi-services restart
  • We created a Systemd service for DarkIce, DietPi will automatically start this:
    systemctl -l status darkice
Access IceCast Web Interface:
  • URL = http://192.168.0.100:8000
  • Admin user = admin
  • Admin password = randomly generated, use code below to view:
    grep admin-password /etc/icecast2/icecast.xml
  • Source password = dietpi
  • Relay password = dietpi
Access Recording File:
This is disabled by default.
  • A recording of the stream can be enabled by editing /etc/darkice.cfg, then un-commenting localDumpFile = /mnt/dietpi_userdata/darkice_recording.ogg
  • Restart services:
  • A recording will then be saved in the following location:
Fourdee
v148
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/camera/#motioneye
MotionEye
Web interface and surveillance for your RPi/USB camera. Mainly focused towards motion detection usage.
NB: Image has been pixelated:
Access web interface: Access recordings (w/o web interface): Upgrade to lastest version:: sudo pip2 install -U motioneye
Fourdee
v149
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/remote ... irtualhere
VirtualHere
Share physically attached USB devices from your SBC, over the network, to other systems. Awesome!
Download Client:
Download the client for your PC: USB Storage WARNING:
As per: https://github.com/Fourdee/DietPi/issue ... -292781475
It it highly recommended, you do not install VirtualHere, if your DietPi user data is stored on a USB drive.
VirtualHere does not take into account mounted drives when selecting them for remote use. This is potentially dangerous for any mounted drive that is in use, and, may cause data loss.
  • Do not use drives, on the client, that are mounted on the SBC.
  • Unmount the drive before hand in dietpi-drive_manager
Fourdee
v149
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittorrent/#sabnzbd
SABnzbd
NZB download manager with web interface.
Access Web Interface: Web interface not loading / Unable to access:
In some instances, initial config generation during installation isn't successful.
If you experience this, please run the following commands to reapply config settings for DietPi (copy and paste all).
systemctl stop sabnzbd
G_CONFIG_INJECT 'download_dir =' "download_dir = /mnt/dietpi_userdata/downloads/incomplete" /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'complete_dir =' "complete_dir = /mnt/dietpi_userdata/downloads/complete" /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'nzb_backup_dir =' "nzb_backup_dir = /mnt/dietpi_userdata/downloads/sabnzbd_nzb_backup" /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'admin_dir =' "admin_dir = /mnt/dietpi_userdata/downloads/sabnzbd_admin" /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'log_dir =' 'log_dir = /var/log/sabnzbd' /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'log_level =' 'log_level = 0' /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'refresh_rate =' 'refresh_rate = 2' /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'host =' 'host = 0.0.0.0' /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'permissions =' 'permissions = 0775' /etc/sabnzbd/sabnzbd.ini
G_CONFIG_INJECT 'auto_browser =' 'auto_browser = 0' /etc/sabnzbd/sabnzbd.ini
systemctl start sabnzbd
Access Downloads: Optional: Multi threaded PAR2: Recommended: Protect your privacy with a VPN:
Fourdee
v149
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/ ... onnect-web
Spotify Connect Web:
Web interface, client and player for Spotify Premium.
Access Web Interface: Generate spotify_appkey.key:
This is required to allow the application, access to Spotify API using your account. Transfer spotify_appkey.key:
Fourdee
v150
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittor ... ouchpotato
CouchPotato
Automatically download movies as they are released.
Recommend additional software:
Access downloads:
  • Make sure you have one of DietPi's File Servers installed.
  • Folders used by Transmission:
    • Download folder = /mnt/dietpi_userdata/downloads
    • accessed from fileserver = /downloads
  • Folders used by CouchPotato:
    • Download folder = /mnt/dietpi_userdata/couchpotato
    • accessed from fileserver = /couchpotato
Locked
