Fourdee
v6.23
Post by Fourdee »
LXQt - Desktop:
Optimized lightweight desktop without the bloatware. Slick and fluid GUI, however, more resource heavy than LXDE.
Desktop can be run by typing startx
You can also have DietPi boot directly to the desktop by using dietpi-autostart and selecting Desktop.
Fourdee
v6.23
Post by Fourdee »
GIMP
Optional desktop application:
MS Paint on steroids. If you need to edit pixels with a vast number of tools, GIMP is the only program you'll need. Just don't be a GIMP about it :D
v6.25
Mycroft AI
Free and open source voice assistant.
Interactive install:
  1. Branch selection: For inexperienced users we recommend the master branch as well: y
  2. Auto updates: It slows down the the startup process a bid, but it anyway takes a while to load all skills, so we recommend this as well: y
  3. Add Mycroft commands to PATH: Chose NO here, since the installer runs as user "mycroft", which is no login user, which is why this has no effect: n
  4. Check code before submitting: If you are an official Mycroft developer, choose y, else: n
Initial setup:
  1. If you did no reboot after install, load Mycroft commands to current shell session: . /etc/bashrc.d/mycroft.sh
  2. Start CLI client: mycroft-cli-client
  3. You should see and at best hear the invitation to pair your device, e.g.: PairingSkill - INFO - Pairing code: XXYYZZ
  4. Visit https://home.mycroft.ai/ to start pairing and configuring your device + skills.
Build Mimic for offline TTS support (optional):
  1. NB: this requires about 3 GiB RAM and takes a while, so assure that you have enough memory (4 GiB recommended), in case increase your swap file size and grab yourself a coffee.
  2. cd /mnt/dietpi_userdata/mycroft-core/scripts
  3. sudo -u mycroft ./install-mimic.sh
v6.27
TasmoAdmin
An administrative website for devices flashed with Tasmota to be used for smart home systems.
Also installs: Webserver (based on your preference), PHP
Implemented by: @svh1985
Access web interface: http://<your_IP/domain>/tasmoadmin
Source code: https://github.com/reloxx13/TasmoAdmin
v6.29
Domoticz
Domoticz is a Home Automation System that lets you monitor and configure various devices like: Lights, Switches, various sensors/meters like Temperature, Rain, Wind, UV, Electra, Gas, Water and much more. Notifications/Alerts can be sent to any mobile device.
- HTTP: http://<your_IP/domain>:8124
- HTTPS: https://<your_IP/domain>:8424
View logs: journalctl -u domoticz
Install directory: /opt/domoticz
Data directory: /mnt/dietpi_userdata/domoticz
Source code: https://github.com/domoticz/domoticz
v6.31
Firefox Sync Server
This is Mozilla's Firefox Sync Server which manages syncing FF instance bookmarks, history, tabs and passwords across devices. Out of the box it runs on a Python server for small loads and can be configured to run behind nginx or Apache.
Configure Firefox:
  • Open about:config to access advanced settings.
  • Search for: identity.sync.tokenserver.uri
  • Set value to: http://<your_local_IP>:5000/token/1.0/sync/1.5
    • We recommend to access your Firefox Sync Server only from local network or via VPN.
    • If you need to access it remotely without VPN, adjust the public_url setting inside the config file /mnt/dietpi_userdata/firefox-sync/syncserver.ini to contain your public IP or domain and desired port.
View logs: journalctl -u firefox-sync
Update method: dietpi-software reinstall 177
Install directory: /opt/firefox-sync
Database and config directory: /mnt/dietpi_userdata/firefox-sync
Source code: https://github.com/mozilla-services/syncserver
Credits: This software title has been added to DietPi-Software by CedArctic, many thanks! :D
Troubleshooting:
If the connection from clients fails, you can try to enable WSGI:
G_CONFIG_INJECT 'force_wsgi_environ =' 'force_wsgi_environ = true' /mnt/dietpi_userdata/firefox-sync/syncserver.ini
This might be required if you connect through a webserver/proxy or for the Android client in general. But enable this only as last resort, first of all assure that public_url is correct.
v6.32
Jellyfin
A FOSS web interface media streaming server, including live TV, forked from Emby.
- http://<your_IP/domain>:8096
View logs:
- Service: journalctl -u jellyfin
- Binary: /var/log/jellyfin/
Data directory: /mnt/dietpi_userdata/jellyfin
Source code: https://github.com/jellyfin/jellyfin
Update to latest version:
apt update
apt install jellyfin jellyfin-ffmpeg
v6.32
Komga
Free and open source comics/mangas media server with web UI
Access web interface: http://<your_IP/domain>:2037
Data directory: /mnt/dietpi_userdata/komga
Configuration file: /mnt/dietpi_userdata/komga/application.yml
Official docs: https://komga.org/guides/
View logs: journalctl -u komga
  • If you require file logging, set a path via config file, like logging: > file: > name: /var/log/komga/komga.log, assure that the directory exists and the "komga" user or group has write permissions.
Source code: https://github.com/gotson/komga
dietpi-software reinstall 179
Locked
