LMS and Squeezelite for PINE A64+ Topic is solved
Gabba
Re: LMS and Squeezelite for PINE A64+
Post by Gabba »
I originally bought a RaspberryPi a few years ago to use LMS and it worked great (I had used SqueezePlug distribution). I'm now using the C2 for Kodi, Transmission, Samba sharing and hope to eventually also to use it for LMS and RetroArch. One of the things that attracted me (with my minimal Linux experience) to DietPi was it's simple usage and the potential for LMS. Everything else is working amazingly and LMS would just be the icing on the cake if you were able to get it working at either 32bit or 64bit. I've made another small donation as your software has been fundamental in getting everything working so far.
mrpn900
Post by mrpn900 »
Fourdee,
I went to see the ticket and noticed that you had solved the problems with LMS, Thank you very much! I tried building those CPAN modules myself befeore contacting you but my knowledge of Linux was not enough. Thank you for your hard work and effort. Looking forward to trying LMS on my PINE 64A,
Mika
mrpn900
Post by mrpn900 »
hello,
I installed DietPi on my PINE 64A. All went well, thank you. Where can I force Squeezelite to output to headphone jack? I did not find any DietPi- config to choose the audio output. I managed to make the needed alsamixer settings to get sound out of HP jack by starting SL with o-option
sysdefault:CARD=audiocodec
Where should I make this correction to make it permanent?
If I install Longsleeps Debian with some GUI, is it possible to use the CPAN-modules you already have created for DietPi?
P.S. made a small donation last week :)
Fourdee
Post by Fourdee »
mrpn900 wrote: sysdefault:CARD=audiocodec
Usually we would create a asound.conf to set the default audio device. However, I just checked my Pine and appears mixer controls are broken:
root@DietPi:/usr# aplay -l
card 0: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
root@DietPi:/usr# amixer -c 0 -D 0 scontrols
ALSA lib control.c:953:(snd_ctl_open_noupdate) Invalid CTL 0
amixer: Mixer attach 0 error: No such file or directory
We currently use the longsleep kernel in our image. So in theory, yes it should work. Here is the CPAN modules for LMS 7.9 ARM64: http://dietpi.com/downloads/binaries/al ... _arm64.zip
mrpn900
Post by mrpn900 »
hello,
ok.Thank you for the information about around.conf.
As a workaround
squeezelite now starts as default:
/usr/bin/squeezelite -n DietPi -a 75
where can I change this line to show:
/usr/bin/squeezelite -n DietPi -o sysdefault:CARD=AUDIO
or better my excellent Encore mDSD
/usr/bin/squeezelite -n DietPi -o sysdefault:CARD=mDSD
I now wish to avoid starting manually each time I reboot pine
edited: found the config-file in /etc/default
mrpn900
Post by mrpn900 »
for me works: alsamixer -c 0
jennifermike
Post by jennifermike »
i am also looking for this Thank you for information
